Meze Audio 109 PRO Headphones
King of comfort with Meze's best tuning yet!
Cup style
Wearing style
Driver type
Amp required
365-day returns
Meze
The Meze Audio 109 PRO is a dynamic driver headphone with an open-back, over-ear design from Antonio Meze and his team from Meze Audio. Coming in at $799, the Meze 109 PRO is easily one of the best looking and most comfortable pairs of headphones you'll find in this price range. The 109 PRO's dynamic drivers produce incredible detail and have upper treble airiness that will satisfy anyone looking at more expensive options like the Hifiman Arya or the Sennheiser HD 800S but are not looking to spend over $1k.Â
Meze Audio 109 PRO - the most anticipated release of 2022 - is finally here
- To achieve the acoustic goals set for the 109 PRO, Meze Audio focused their R&D work on materials research, looking for the perfect balance between cone mass and stiffness to maximize the headphones' sonic capabilities.
- Meze Audio's search led to the development of the 109 Series dual cone diaphragm - a combination of beryllium-coated polymer, cellulose and carbon fibre composite and a copper-zinc alloy.
- Acoustic design at its finest - the spider-like structure and acoustically transparent grille inside the ear cup exposes the driver from both sides, creating Meze's most open soundscape yet.
- The velour pads comfortably enclose the ears and ensure an optimal seal to produce a natural sound. Since velour is much softer and more breathable than leather, it also prevents sweat build-up and overheating during extended listening sessions.
- The 109 PRO is all about comfort - from the headphone's structural design to the choice of materials, all decisions have been carefully made to ensure the final product meets our highest standards of ergonomics.
- With this in mind, Meze Audio have combined walnut wood, zinc, manganese steel and vegan leather into a comfortable, lightweight yet extremely strong structure.
- Meticulously tuned by Meze's in-house engineering team, the 109 PRO offers an emotionally engaging sound with great detail, clarity and just the right amount of punch.
- Its organic character, coupled with superior dynamics, excellent imaging and full-bodied voices, brings soul-stirring details to life. Plus, it's easy to control from most devices, whether they're portable sources or complex home systems.
Highlights
- Dynamic open-back circumaural (over-ear) headphone
- Driver features the 109 series Dual Membrane Diaphragm – a combination of Beryllium-coated polymer, cellulose + carbon fibre composite and copper-zinc alloy
- Easy to drive from most devices, from portable sources to full home setups
- Dark walnut wood ear cups, zinc, manganese steel, vegan leather headband and soft velour ear pads for a comfortable, lightweight, yet highly durable structure
WHAT'S IN THE BOX?
- Case: Hard EVA pouch
- Included cables:
1.5m soft TPE cable, with black aluminum casings, ending with 3.5 mm jack
3m soft TPE cable, with black aluminum casings, ending with 3.5 mm jack - Headphone termination: 3.5 mm TRS jack
- Included adapters: 6.3mm gold-plated jack
TECHNICAL SPECIFICATIONS
- Transducer Size: 50mm
- Frequency Response: 5Hz - 30KHz
- Sensitivity: 112dB SPI at 1KHz, 1mW
- Impedance: 40 Ω
- Weight: 375 gr (13 oz) without cables
- Ear Cups: Walnut Wood
