Hifiman
Hifiman Edition XV Headphones - Open Box
Regular price $329
Sale price $329 Regular price $399.00
Save 18%
1 of 8
Hifiman
Regular price $329
Save 18%
A Familiar Sound, Modernized
Edition XV pushes the Edition X line forward with a thinner second-gen diaphragm, a lighter headband with rotating hinges, and user-friendly 3.5mm connectors. The goal: keep the speed and clarity fans expect, make it easier to wear for hours, and keep amplification requirements reasonable.
Hifiman Edition XV Review from The Audio Files
For a deep dive into how the Edition XV compares to past HIFIMAN releases, reviewer Griffin Silver (@Listener) shares his take in The Audio Files (also video review below.
His review, “HIFIMAN Edition XV Review: Brilliance in Darkness,” explores the headphone’s tuning changes, design refinements, and where it fits among other mid-fi favorites like the Edition XS and Sennheiser HD 650.
Read the full review
What’s New (And Why It Matters)
  • Enhanced magnet design (rare-earth-free): Precision-shaped permanent magnets target lower distortion and cleaner transients without relying on rare-earth materials. The claim is parity-level sensitivity vs. neo magnets, with better sustainability.
  • NEO Supernano Diaphragm Gen.2: About 60% thinner than first-gen. Less mass → quicker start/stop behavior → more microdetail and snap.
  • Composite headband, Gen.2: Weight trimmed ~20–30 g with rotatable hinges to improve fit across head shapes.
  • 3.5 mm cup connectors: Angled, user-replaceable cable that plays nicely with common aftermarket options.
How It Should Sound
Edition XV aims for the wide, open presentation that made the series popular, with faster transients from the thinner film and a bit more comfort for long sessions. On paper, 12 Ω / 92 dB suggests it’s friendlier to modern desktop amps and capable dongles, but you’ll still get the best control and dynamics from a clean desktop source.
Power guidance (plain English)
Edition XV is rated 12 Ω / 92 dB. It will play from many sources, but it scales with a proper desktop amp. Aim for sources capable of ≥1–2 Vrms with solid current delivery for full dynamics and bass control. A compact USB-C dongle DAC/amp works in a pinch; a clean desktop stack is better.
If you want to drill down on power requirements, check out Headphones.com's Power Calculator here
Which HIFIMAN fits your setup?
Quick differences that impact power needs, comfort, and presentation.
Feature Edition XV Edition XS Ananda
Type Open-back planar Open-back planar Open-back planar
Frequency Response (claimed) 8 Hz – 50 kHz 8 Hz – 50 kHz 8 Hz – 55 kHz
Impedance 12 Ω 18 Ω ~27 Ω
Sensitivity 92 dB ~92 dB ~103 dB
Weight 452 g ~405 g ~399 g
Diaphragm NEO Supernano Gen. 2 (≈60% thinner) NEO Supernano (Gen. 1) Ultra-thin planar film
Headband Composite Gen. 2, rotatable hinges Suspension headband Suspension headband
Cup Connectors Dual 3.5 mm (angled) Dual 3.5 mm Dual 3.5 mm
Power / Pairing Tips Scales with desktop amps; target ≥1–2 Vrms with good current. Similar drive to XV; desktop amp recommended for headroom. Easier to drive than XV/XS; still improves with clean desktop power.
Who it suits Detail-first listeners who want snap and dynamics with modern comfort. Budget planar fans seeking wide stage and strong value. Those wanting a more efficient HIFIMAN with an airy, open presentation.
Hifiman Edition XV Technical Specifications
Specification Details
Type Open-back, planar magnetic
Frequency Response 8 Hz – 50 kHz
Impedance 12 Ω
Sensitivity 92 dB
Weight 452 g (approx.)
Diaphragm NEO Supernano Diaphragm Gen. 2 (≈60% thinner vs Gen. 1)
Magnet Design Newly engineered magnet structure (see product copy for details)
Headband Composite, Gen. 2, rotatable hinges (20–30 g lighter vs prior)
Ear Pads Memory foam pads (velour + pleather wrap)
Cable Detachable 3.5 mm cable (user-replaceable)
What’s in the Box
  • HIFIMAN Edition XV Planar Magnetic Headphones
  • Detachable dual 3.5 mm headphone cable
  • 6.35 mm (1/4") adapter
  • User manual & warranty card
Frequently Asked Questions
Do I need an amplifier for the HIFIMAN Edition XV?
Edition XV is rated at 12 Ω / 92 dB. It will play from many sources, but for full dynamics and bass control we recommend a desktop headphone amp or a high-quality dongle capable of ≥1–2 Vrms with solid current delivery.
Check out our Headphone Power Calculator for more information.
What cable and connectors does Edition XV use?
Edition XV uses dual 3.5 mm connectors at the cups (angled). A detachable 3.5 mm cable is included and is user-replaceable. Hifiman does not use proprietary cable connections like other manufacturers.
If you're looking for the perfect affordable replacement to the stock cable, check out our in-house Listenmore Etched Headphone Cables. Terminations include 4.4mm, 4-pin XLR, 3.5mm and 6.35mm.
Is the Edition XV open-back or closed-back?
Edition XV is an open-back planar magnetic headphone.
What is included in the box?
HIFIMAN Edition XV headphones, detachable 3.5 mm cable, 6.35 mm (1/4\") adapter, and user manual/warranty card. Contents may vary by region.
What is your return policy for this product?
Headphones.com offers 365-day returns with no restocking fees. Customers are responsible for return shipping. See our returns page for details.
How much does the Edition XV weigh?
Approx. 452 g.
Customer Reviews
Overall rating: 5.0 / 5 from 2 reviews.
This now might be the new gold standard for reference quality, audiophile gateway headphones for under $500. I would put these in the same league as the HD 600/650/6XX series in terms of “gold standard” sound.
Customer photo review of Hifiman Edition XV Headphones - Open Box
Smells and looks basically brand new. Sounds absolutely amazing as well. Bass and sound stage is an upgrade in comparison to another warm headphone I own (Aune AR5000).
