Hifiman
Hifiman Ananda Unveiled Headphones - Open Box
Cup style
Wearing style
Driver type
Amp required
Portability
Removing the Veil
The Ananda Unveiled introduces technology first seen in the 2024 Susvara Unveiled: eliminating the grille structure that reflects and refracts sound back into the diaphragm. By removing these obstructions, the Unveiled design aims to deliver a purer, more transparent presentation than previous Anandas.
Open, Unfiltered Sound
Traditional mesh grilles can reflect or scatter sound waves, interacting with the ultra-thin diaphragm and creating subtle distortion. HIFIMAN’s Unveiled system removes that layer, producing a more direct, uncolored wavefront. The result: a sense of openness and clarity closer to what the driver itself is capable of.
Enhanced Magnet System
The Ananda Unveiled employs a precisely shaped magnet array that reduces distortion without losing control or dynamics. It’s designed for sensitivity comparable to rare-earth systems while minimizing reliance on those materials.
Second-Generation Supernano Diaphragm
The diaphragm is now ~60% thinner than the original, allowing faster transient response and greater detail retrieval. This change helps the Unveiled keep up with dense mixes and high-resolution recordings while maintaining HIFIMAN’s planar speed and texture.
Comfort and Practical Updates
A Gen. 2 composite headband trims weight (15.8 oz / ~448 g), while rotatable hinges improve seal and long-term wear. The dual 3.5 mm connectors angle outward for durability and ease of cable swaps. Magnetic protective veils fit over the cups when not in use, shielding the open drivers.
Compare the Hifiman Ananda and Arya Lineup
| Feature | Ananda Unveiled | Ananda Stealth | Arya Stealth |
| Type | Open-back planar | Open-back planar | Open-back planar |
| Frequency Response | 5 Hz – 55 kHz | 8 Hz – 55 kHz | 8 Hz – 65 kHz |
| Impedance | 22 Ω | 27 Ω | 32 Ω |
| Sensitivity | 93 dB | ~92 dB | ~94 dB |
| Weight | 15.8 oz (≈448 g) | ~440 g | ~404 g |
| Unique Features | Unveiled grille-free design, magnetic protective veils | Stealth magnets, traditional grille | Stealth magnets, larger driver, wider stage |
| Who it suits | Listeners who want maximum transparency and minimal acoustic obstruction | Fans of the Ananda tuning who prefer smoother treble and efficient drive | Those chasing a wider soundstage and stronger imaging performance |
Hifiman Ananda Unveiled Technical Specifications
| Specification | Details |
| Type | Open-back, planar magnetic |
| Impedance | 22 Ω |
| Weight | 15.8 oz (≈448 g, excluding veils & cable) |
| Diaphragm | NEO Supernano Diaphragm Gen. 2 (≈60% thinner vs Gen. 1) |
| Magnet Design | Precision-shaped permanent magnet system |
| Headband | Composite Gen. 2, rotatable hinges |
| Cup Connectors | Dual 3.5 mm (angled) |
What’s in the Box
- HIFIMAN Ananda Unveiled Planar Magnetic Headphones
- Magnetic protective veils (pair)
- Detachable dual 3.5 mm headphone cable
- 6.35 mm (1/4") adapter
- User manual & warranty card
Frequently Asked Questions
What does “Unveiled” mean in the Ananda Unveiled?
How does the Ananda Unveiled differ from the Ananda Stealth?
Does the Ananda Unveiled need an amplifier?
What are the Magnetic Veils used for on the Ananda Unveiled?
How comfortable are the Ananda Unveiled?
What is included in Ananda Unveiled box?
What is the warranty and return policy for the Ananda Unveiled?
