Aune AR5000 mk2 vs AR3000... and more!
Join Resolve as he compares the Aune AR5000 mk2 and AR3000 and shares who each one suits best.
There is an obvious family resemblance between these two, but I do not think they are chasing the same result. In broad terms, I hear the AR5000 mk2 as the one built around treble liveliness, finer detail around the edges of tones, and a more spacious presentation. The AR3000 is the more natural-sounding one to me, with better overall timbre and, frankly, ridiculously punchy bass.
If you are trying to decide between them, I would not frame this as a strict upgrade path so much as a preference fork. One of these is easier to live with across a big library. The other is more specialized, and when it clicks, I can absolutely hear why someone would prefer it.
Sound signature differences
The AR5000 mk2 is the clarity-first option. As said, I get that more apparent-feeling "outline" around the edges of notes, and more of that airy spaciousness effect that can make a headphone feel open and incisive. On the right material, that can sound genuinely refreshing rather than just "bright".
The AR3000 goes in a different direction. I hear it as more natural in timbre, more grounded, and considerably more satisfying in the low end. It has more bass presence, better bass extension, and a punchier overall presentation. So while it may not chase the same shimmering top-end effect, it really doesn't have to, because it sounds more balanced and more usable to me across a broader spread of music.
Treble and detail
This is where the AR5000 mk2 makes its best case, but also where it potentially gets itself into trouble.
With instrumental music, jazz, and generally good recordings, that extra sense of clarity comes through and can be pretty delightful. Brushes on cymbals, the initial flutter of a note, the immediate pluck of a guitar string, those sorts of details are pushed forward a bit more, and not necessarily in a fake-feeling way, but in a way that makes you pay extra attention to things other headphones may not highlight as much.
With that said, I also think this is clearly a result of the exaggeration in the mid and upper treble. The AR5000 mk2 is not what I would call broadly harsh in the usual lower-treble sense, but it can absolutely get hot & spicy up top, and yes sometimes that turns into sibilance.
Worse recordings are where it gets exposed quickest, obviously. If a mix already has aggressive consonant/fricative sounds or a bit of glariness baked in, this headphone is not going to politely look the other way.
And this is exactly where AR3000's extra restraint may be preferable. Its treble comes across as more relaxed and subdued by comparison, which means yes, it gives up some of that spotlighted shimmer, but in my view it also avoids the AR5000 mk2's tendency to overdo things.
So yes, the AR5000 mk2 can sound clearer, but this comes at the cost of versatility.
Bass and low-end character
The AR3000 has the more convincing low end. I hear more bass quantity, better extension, and more punch, and that contributes meaningfully to why I find it more versatile. It is simply easier for me to throw different genres at it without feeling like the tonal balance is arguing with the music.
That said, the AR5000 mk2 does still have some low-frequency elevation, and I would not call it bass-light in an absolute sense. It's just that next to the AR3000 it is the less bassy, less physical-feeling/less punchy option, simply because its priorities are elsewhere.
If you want a more clarity-focused presentation and are happy to trade some low-end heft for that, then fair enough, that is the AR5000 mk2's pitch. I just think the AR3000's bass tuning makes better sense for more people and more music.
Measurements
AR5000 mk2 is mostly following our updated preference bounds, with extension through the bass and some elevation in the low frequencies into the low mids, followed by a dip around 2 kHz, then a more forward treble presentation.
In direct comparison, the AR3000 measures with notably more bass and better bass extension, while the AR5000 mk2 is more forward in the upper treble. That is basically the trade-off in one sentence: more punch and naturalness on one side, more airy shimmer and apparent detail on the other.
My own on-head measurement impression of the AR5000 mk2 is especially telling here to why I find it firmly on the bright side: Everything looks mostly fine until around 7 kHz, above which there is a notable elevation.
Perceptually, that rise is wider/smoother than a single narrow spike, with the region from roughly 7 kHz to 12 kHz sitting at least about 5 dB forward on my head. That does not automatically make it bad, but it absolutely explains why the headphone can sometimes sound sharp or sibilant.
Fit and variability
One complication with both of these headphones is that their response can vary depending on positioning. Because they use strongly angled drivers, how far forward or backward it sits relative to your ear can change the result, and different heads and ears are likely to shift that response as well. So if someone else hears it as slightly less aggressive or slightly more aggressive than I do, I would not find that surprising.
That does not erase the tuning tendencies, but it does mean the AR5000 mk2 may be somewhat more placement-sensitive than a simpler design would be. In other words, this is not the sort of headphone where I would assume every impression translates perfectly from one person to the next.. but we'd really not expect that of most headphones anyway.
Comfort and build
Ergonomically, these are basically the same. They wear the same, feel the same, and both are quite comfortable. I would also put both of these less expensive models above the AR9000 for comfort, mostly because they are lighter, even if the construction does not feel quite as robust as the AR9000.
The notable build change mentioned for the AR5000 mk2 is the headband adjustment connector area. The move to the "mk2" version from the original was partly tied to reports that the original AR5000 could snap at that headband connection point, and Aune says this was improved here.
The same improvement was also apparently integrated into the AR9000 and AR3000 before release, which is good to hear, but I would still treat long-term durability as something that'll only become clear after people have lived with them for a while.
Aesthetically, I prefer the AR3000. That is subjective and not exactly a grand technical insight, but yes, I would take the black finish over the silver look. They both remain pretty understated overall, though, which I generally appreciate.
Verdict
I prefer the AR3000 overall. To my ears it is the more versatile tuning, the more natural-sounding one, and the one that makes fewer demands about what you listen to and how well it was recorded. It has the better bass performance of the two, and for most people I think it is simply the easier recommendation.
That does not mean the AR5000 mk2 is a miss. It is just more niche, and I would only point you there if you specifically want a more treble-focused presentation with extra shimmer, extra edge definition, and a more spacious, incisive character, while accepting that it can sometimes go overboard. Some listeners are going to love that. I just do not think it is the safer choice.
Within the broader Aune lineup, my ranking is straightforward: AR9000 first, AR3000 second, AR5000 mk2 third. The AR9000 remains the one that impresses me most, largely because I really like how it handles bass. But between the two here, I think the picture is pretty clear. The AR3000 is the all-rounder. The AR5000 mk2 is the specialist, and specialists are fun right up until they are not.
