TRUTHEAR
Truthear Pure In-Ear Headphones
Regular price $89.99
Sale price $89.99 Regular price $89.99
1 of 9
TRUTHEAR
Preorder now More information
Pre-order now Expected to ship soon
Truthear Pure In-Ear Headphones - Exceptional Sound Quality at $89.99
The Truthear Pure In-Ear Headphones offer a remarkable listening experience, combining advanced technology with practical design. At a price point of $89.99, these headphones provide a compelling value proposition for both audiophiles and casual listeners. With insights from expert reviews, these headphones are noted for their hybrid 4-driver configuration, which includes a dynamic driver for bass and balanced armature drivers for mids and highs. This setup ensures a well-balanced sound profile across all frequencies, making them a standout choice in their price range.
What Makes the Truthear Pure In-Ear Headphones Stand Out
The Truthear Pure In-Ear Headphones are designed with portability and high-quality sound in mind. The hybrid 4-driver configuration combines a 10mm dynamic driver with three balanced armature drivers, delivering a rich and detailed audio experience. This setup is particularly beneficial for mobile listening, providing clear and punchy sound that enhances your music on the go.
Technical Foundation:
The headphones feature a silicone suspension and LCP dome composite diaphragm, with an impedance of 13.8Ω±15% @1kHz and a sensitivity of 124dB/Vrms @1kHz. These specifications ensure efficient power usage and compatibility with portable devices, providing a wide frequency response from 7-40kHz, with an effective range of 20-20kHz for optimal performance with smartphones and portable players.
Sound Performance Analysis
The Truthear Pure In-Ear Headphones deliver an impressive listening experience across various scenarios:
  • Bass: The dynamic driver provides impactful bass that remains controlled even in noisy environments, suitable for genres like EDM and hip-hop.
  • Midrange: Vocals and instruments are clear and well-separated, making these headphones ideal for commuting where clarity is essential.
  • Treble: Highs are detailed without causing fatigue, allowing for extended listening sessions.
  • Imaging and Isolation: The headphones offer excellent stereo positioning and passive noise isolation, enhancing the listening experience in busy settings.
These qualities make the Truthear Pure ideal for a variety of music genres and mobile listening scenarios, including commuting, travel, and indoor critical listening.
Build Quality and Fit
The Truthear Pure In-Ear Headphones boast a DLP 3D printed cavity made from medical-grade, high-transparency resin, ensuring lightweight and skin-friendly construction. The premium copper silver-plated cable is detachable, featuring 0.78mm 2-pin connectors for flexibility and superior sound quality. The ergonomic design and selection of ear tips accommodate different ear shapes, providing comfort for extended wear.
Perfect For These Applications
For Daily Commuting:
The headphones offer excellent isolation, comfort, and sound quality, making them perfect for public transport and urban environments.
For Critical Listening & Travel:
Their design and performance make them suitable for stationary listening, travel, or indoor environments where audio quality is prioritized.
Equipment Pairing:
The headphones are compatible with smartphones and portable players, and their impedance and sensitivity make them suitable for use with portable amplifiers, optimizing mobile listening.
How It Compares
When compared to other IEMs in the market, such as the Moondrop Starfield and the Tin HiFi T4, the Truthear Pure offers a more balanced sound profile with enhanced bass and detailed highs. Priced at $89.99, it provides excellent value, especially for those seeking a versatile sound profile suitable for various listening scenarios.
Key Features
  • Hybrid 4-Driver Configuration (1DD + 3BA) - Combines a 10mm dynamic driver for punchy bass with three balanced armature drivers for clear mids and detailed highs, delivering well-balanced sound across all frequencies.
  • DLP 3D Printed Cavity - Uses medical-grade, high-transparency resin with precision DLP 3D printing technology for enhanced acoustic design and lightweight, skin-friendly construction.
  • Advanced Frequency Crossover System - Features an accurately calculated RC frequency crossover with specialized nozzle filtering that optimizes each driver's performance for seamless three-frequency integration.
  • Premium Copper Silver-Plated Cable - Includes a high-quality oxygen-free copper coaxial cable with silver plating and detachable 0.78mm 2-pin connectors for superior sound quality and cable swapping flexibility.
  • Professional Tuning & Measurements - Tuned to match advanced HATS (Head and Torso Simulator) target curves with optimized bass gain, reduced resonance peaks, and high phase consistency across all frequency bands.
  • Versatile Sound Profile - Delivers natural, well-balanced sound suitable for monitoring, music listening, and gaming with enhanced bass punch, solid midrange, and bright, detailed highs compared to its predecessor.
Specification Details
Driver 1 x Dynamic Driver + 3 x Balanced Armature Drivers
Diaphragm Silicone Suspension + LCP Dome Composite Diaphragm
Impedance 13.8Ω±15% @1kHz
Sensitivity 124dB/Vrms @1kHz
Total Harmonic Distortion THD≤1% @1kHz (94dB)
Frequency Response Range 7-40kHz (IEC61094, Free Field)
Effective Frequency Response Range 20-20kHz (IEC60318-4, -3dB)
Price $89.99
Practical Considerations
These headphones come with a variety of ear tips to ensure a perfect fit for different ear shapes, enhancing comfort and sound isolation. The detachable cable allows for easy replacement and reduced microphonics, making them ideal for portable use. Regular maintenance and cleaning will ensure long-term durability, and their compatibility with a range of devices makes them a versatile choice for daily use.
Value Assessment
At $89.99, the Truthear Pure In-Ear Headphones offer exceptional value for their sound quality and build. Compared to other IEMs in the same price range, they provide a more balanced and detailed sound, making them a worthwhile investment for those seeking high-quality portable audio.
Frequently Asked Questions
General Q: What is the warranty period for the Truthear Pure In-Ear Headphones?
A: The headphones come with a one-year warranty covering manufacturing defects.
Technical Q: Are the cables detachable?
A: Yes, the headphones feature detachable cables with 0.78mm 2-pin connectors.
Usage Q: Can these headphones be used for gaming?
A: Yes, the versatile sound profile makes them suitable for gaming, providing clear audio cues and immersive sound.
