RAAL-Requisite
RAAL-Requisite SR1a with Schiit Audio Jotunheim R - Open Box
Regular price $2,999
Sale price $2,999 Regular price $4,200.00
1 of 4
RAAL-Requisite
Jotunheim R
Designed by Shiit Audio, for RAAL-requisite headphones.
This amp was developed for one kind of headphones only: the RAAL-requisite ribbon headphones. Delivering up to 13A (amps…yes, amps) per channel into RAAL’s extremely low impedance load, and including the baffle compensation needed for the SR1a. It means you can leave your speaker amp behind, forget the RAAL-requisite interface box, and, if you buy it with the optional True MultibitTM DAC, you have a one-box system that’s easily transportable.
The SR1a by RAAL-requisite is the world’s first Earfield™ Monitor. Experience mixing, mastering, and home listening with unparalleled accuracy and realism in a sound field devoid of room acoustics and comb-filtering caused by work surface reflections. Earfield™ technology delivers unheard of program accuracy and a speaker-like sound field experience.
Finest materials. Hand built.
The SR1a features; carbon fibre baffles, stainless spring steel headband, aluminum ribbon drivers, plush memory foam bars, and lambskin leather (non-leather option available). Every SR1a is expertly handmade, in Serbia, by the skilled European craftspeople who build world-renowned RAAL ribbon tweeters.
