Pro-Ject Audio Systems
Pro-Ject Audio Systems Debut Carbon EVO - Open Box - Clearance
Regular price $249
Sale price $249 Regular price $599.00
1 of 9
Clearance
Regular price $249
Open-box items in C condition are open box items that are not in like-new condition. They may show signs of wear, have packaging that is imperfect and be missing accessories. Clearance items are sold as is without a warranty guarantee and no returns.
Debut Carbon EVO Manual 3-Speed Turntable
An upgrade to the successful Debut Carbon, the satin yellow Debut Carbon EVO Manual Three-Speed Turntable from Pro-Ject Audio Systems maintains the line's high performance and clean aesthetics. Pro-Ject leverages their skilled engineering to improve many features, resulting in less resonance and audiophile-quality analog sound. A factory-mounted and aligned Sumiko Rainier MM phono cartridge delivers superb trackability as your prized records rest on a heavy, TPE-dampened 12" steel platter spun by a decoupled and TPE-dampened motor. Everything is fitted onto a solid MDF plinth that's been treated with a stunning eight-coat lacquered paint job. Even the metal feet are TPE-dampened and adjustable, ensuring the Carbon EVO enjoys a level surface.
Highlights
  • Sumiko Rainier MM phono cartridge
  • Massive TPE-damped steel record platter
  • Motor, motor shielding & suspension
  • Electronic speed changer & stabilizer
  • Adjustable TPE-damped isolation feet
  • Satin finishes incl. real walnut veneer
The Evolution
The Debut Carbon EVO focuses on the core aspects that make a turntable sound great. Technically correct design - expert craftsmanship - handmade in the EU. This turntable is built to last you a lifetime!
Redesigned motor suspension
We used our technology and experience gained from the past and fit damping techniques of highend turntables into the Debut Carbon EVO. Looking at more advanced TPE damping and highmass sandwich constructions we were able to come up with a new motor and suspension solution for the Debut Carbon EVO.
Anytime the perfect stand
Our new Debut Carbon EVO does not just look great - it also always stands perfectly level. It uses 3 height adjustable heavy-duty metal feet to ensure a level positioning on every surface.
Controlled playback speeds
Besides being able to effortlessly change replay speeds with the push of a button, the playback speed is electronically controlled with the utmost precision, which results in the most accurate and stable speeds.
DAMPED FROM THE INSIDE
Our previous metal platter was already heavier than anybody else‘s on the market, but metal platters inherently have a disadvantage: resonance.
Our TPE (thermoplastic elastomer) technology now helps to damp the resonance completely and also increases the weight to 1,7 kg. Because the TPE is mounted to the inside of the platter‘s rim, the moving energy will also create a flywheel effect. The result is an even quieter and noiseless operation with less wow and flutter.
CLEAN LOOK & NEW COLOURS
You wont find any button, switch or printing on the plinth to ensure the luxurious aesthetics. The speed control switch has been moved to the bottom of the plinth, to keep the clean look the Debut is known for.
The Debut Carbon EVO is not only timeless by offering traditional high-gloss black, white and red finishes or our fabled real-wood walnut veneer. Completely new, unique and trend-setting are the beautifully realized satin signature finishes in 5 different variations.
