Noble Audio
Noble Audio FoKus Triumph True Wireless In-Ear Headphones
Revolutionary xMEMS sound on the go
Wearing style
Driver type
Wireless
Portability
Experience the future of true wireless sound with the Noble Audio FoKus Triumph, the latest flagship in-ear monitor (IEM) that brings together cutting-edge technology and audiophile-grade performance in a convenient TWS package. At the heart of the FoKus Triumph is a custom-made 6.5mm dynamic driver paired with a revolutionary Cowell xMEMS driver. This hybrid configuration delivers a rich, dynamic soundscape with deep, controlled bass, lush mids, and crystal-clear highs, ensuring you hear every detail in your music with stunning clarity.
Revolutionary Driver Technology
The FoKus Triumph sets a new standard in wireless audio with its dual-driver setup. The 6.5mm dynamic driver is finely tuned to provide impactful bass that is both powerful and precise. Complementing it is the xMEMS driver, a state-of-the-art technology that enhances high-frequency resolution with remarkable fidelity. Known for its fast response and high resonant frequency, the xMEMS driver ensures that the high notes are rendered with exceptional clarity, free from distortion or muddiness. Together, these drivers create a balanced and immersive sound signature that rivals the performance of wired IEMs.
Ergonomic and Elegant Design
Crafted for both comfort and style, the Noble Audio FoKus Triumph features a seamless, ergonomic shell that is 3D printed for a semi-custom fit. The low-profile design ensures a secure and comfortable fit for extended listening sessions. Each earpiece is adorned with a hand-painted faceplate, adding a touch of uniqueness and luxury. The stainless steel nozzle is designed with a reduced diameter for improved comfort, while the embedded touch sensor allows for intuitive control of your music and calls.
Advanced Connectivity and Features
Under the hood, the FoKus Triumph is powered by the Qualcomm SoC QCC3071 chip, ensuring stable and efficient performance. The Bluetooth 5.3 connectivity supports a wide range of codecs, including LDAC, Snapdragon Sound, SBC, AAC, APTX, and APTX adaptive, allowing you to enjoy high-quality, lossless audio wirelessly. The earbuds also feature advanced capabilities such as true wireless mirroring, multi-pairing, and multi-connection, giving you the flexibility to connect to multiple devices simultaneously.
Long-Lasting Battery Life and Premium Charging Case
The FoKus Triumph is designed to keep up with your lifestyle, offering up to 7.5 hours of playback on a single charge at 50% volume. The stylish charging case, wrapped in premium Italian Alcantara, provides four additional charges, extending the total battery life to over 30 hours. The case supports wireless charging, making it easy to keep your earbuds powered up on the go. With a 500mAh battery, the case ensures that your FoKus Triumph is always ready when you are.
Customizable Sound with Noble FoKus App
Take control of your audio experience with the free Noble FoKus app, available on both Google Play and the Apple App Store. The app features a 10-band equalizer with customizable presets, allowing you to fine-tune the sound to your liking. It also includes a hearing test function that personalizes your EQ settings based on your hearing profile, ensuring the best possible sound quality tailored specifically to you. The app also allows you to control the transparency mode, giving you full control over your listening environment.
| Specification | Details |
| Drivers | 6.5mm Dynamic Driver, 1 xMEMS Cowell Driver |
| Frequency Response | 20Hz-2000kHz |
| Chip | Qualcomm SoC QCC3071 |
| Bluetooth Version | 5.3 |
| Supported Codecs | LDAC, SBC, AAC, APTX, APTX Adaptive, Snapdragon Sound |
| Operating Range | Up to 39' for Android, 59' for iPhone |
| Battery Life (Earbuds) | 7.5 hours at 50% volume |
| Battery Life (Case) | 500mAh, 4 extra charges |
| Charging Time (Earbuds) | 1.5 hours |
| Charging Time (Case) | 1.5 hours |
| Wireless Charging | Supported |
| App Compatibility | Noble FoKus App with 10-band EQ and Presets |
| App Language Support | English, Japanese, Traditional Chinese, Simple Chinese, Korean, Russian |
What's Included
- Noble Audio FoKus Triumph Earbuds
- Premium Alcantara-Wrapped Charging Case
- Selection of Ear Tips for Custom Fit
- USB-C Charging Cable
- User Manual
Elevate Your Listening with the Noble Audio FoKus Triumph
The Noble Audio FoKus Triumph sets a new benchmark in true wireless audio performance. With its advanced dual-driver configuration, superior connectivity features, and customizable sound options, the FoKus Triumph offers an unparalleled listening experience. Available now at Headphones.com, the FoKus Triumph is the ultimate choice for those who demand the very best in wireless audio technology and design. Discover the difference with Noble Audio's flagship true wireless in-ear headphones.
