Build quality was gratifying for the Artemis. They are an enjoyable headphone that with certain songs can make you think Wow, but are consistent enough to hang with other top tier headphones in their price range.
Noble Audio
Noble Audio FoKus Artemis Wireless Headphones - Open Box
Cup style
Wearing style
Driver type
Planar Magnetic, Dynamic, Balanced Armature
Wireless, Wired
Portability
The Noble Audio FoKus Artemis is a flagship wireless over-ear headphone built for listeners who want high-end sound without giving up the convenience of a modern everyday headphone. It brings together a rare hybrid three-driver system, premium wireless performance, active noise cancellation, USB audio, wired listening support, and a self-replaceable battery in one refined full-size design.
Artemis is designed to feel like a true Noble headphone first. The sound is built around scale, detail, and immersion, with a dynamic driver for weight and impact, a balanced armature for clarity and articulation, and a planar driver for speed and openness. It is a more ambitious approach than a typical wireless headphone, giving Artemis the kind of layered, high-resolution presentation that better matches what serious listeners expect from Noble.
Hybrid Three-Driver Sound
Most wireless over-ear headphones rely on a single dynamic driver. FoKus Artemis takes a different path with a hybrid driver configuration that combines three driver technologies inside each side of the headphone. The dynamic driver brings body, punch, and low-end authority. The balanced armature adds definition through vocals, instruments, and upper-frequency detail. The planar driver contributes speed, control, and a more open sense of space.
The result is a headphone tuned for a spacious, detailed, and powerful listening experience. Artemis is built for music that needs room to move, whether that means the scale of electronic music, the layering of orchestral recordings, the texture of vocals, or the punch and energy of modern mixes.
Personalized Listening with Audiodo
FoKus Artemis includes Audiodo Personal Sound, giving listeners a more tailored experience based on their own hearing profile. Instead of relying only on a fixed factory tuning, Artemis can adapt the listening experience to better match the way you hear.
That makes the headphone more personal without taking away from Noble’s core sound philosophy. You still get the scale, clarity, and refinement of the hybrid driver system, with added flexibility to make the presentation feel more natural to you.
Wireless When You Want It, Wired When You Need It
Artemis is built on the Qualcomm QCC3095 platform with Bluetooth 6.0 for stable modern wireless performance. Codec support includes SBC, AAC, aptX, aptX HD, and LDAC, giving you strong compatibility across phones, tablets, laptops, and high-resolution wireless sources.
For listeners who want a direct connection, Artemis also supports USB audio and 3.5mm wired audio through the included USB-C to 3.5mm cable. That flexibility makes it easy to use Artemis across more devices, whether you are listening wirelessly from your phone, plugging into a laptop over USB-C, or using a wired connection when Bluetooth is not the right fit.
Built for Everyday Use
FoKus Artemis is a flagship headphone, but it is not built only for quiet rooms and perfect conditions. Active Noise Cancellation helps reduce outside distractions when you want to focus, while Transparency Mode lets outside sound back in when you need awareness. Multipoint connectivity makes it easier to move between devices, and the six-microphone design supports clearer voice pickup for calls and meetings.
The long battery life makes Artemis easy to use throughout the week. Playback is rated for more than 50 hours with ANC off and more than 35 hours with ANC on, while fast charging helps you get back to listening quickly. The 600mAh battery is also fully self-replaceable, giving Artemis a stronger long-term ownership story than most premium wireless headphones.
A Flagship Wireless Headphone with a Longer View
The self-replaceable battery is one of Artemis’s most important design choices. Wireless headphones are often limited by battery lifespan, even when the acoustic design still has years of use left. By making the battery customer replaceable, Noble gives Artemis a more practical path for long-term ownership.
That fits the larger idea behind FoKus Artemis: a wireless headphone that feels premium now, but also makes sense beyond the first couple years of use. With hybrid drivers, premium codec support, USB and wired listening, app-based control, ANC, and a replaceable battery, Artemis is built to be more than a convenience headphone. It is Noble’s flagship wireless over-ear for listeners who care about sound, design, and longevity.
Key Features
- Flagship wireless over-ear headphone from Noble Audio
- Hybrid three-driver configuration with dynamic driver, balanced armature, and planar driver
- Spacious, detailed, and powerful sound designed for serious music listening
- Audiodo Personal Sound for a more tailored listening experience
- Qualcomm QCC3095 wireless platform
- Bluetooth 6.0 connectivity
- SBC, AAC, aptX, aptX HD, and LDAC codec support
- Active Noise Cancellation for reducing outside noise
- Transparency Mode for environmental awareness
- Multipoint connectivity for switching between devices
- USB audio support
- 3.5mm wired audio support via included USB-C to 3.5mm cable
- Six-microphone design
- Noble FoKus app support with EQ, OTA updates, and multi-language support
- 600mAh full self-replaceable battery
- More than 50 hours of playback with ANC off
- More than 35 hours of playback with ANC on
- Fast charging with full charge in under 1.5 hours
- IP52 water resistance
Technical Specs
| Product Type | Wireless over-ear headphone |
| Driver Configuration | Hybrid three-driver system |
| Drivers | Dynamic driver + balanced armature + planar driver |
| Frequency Response | 10Hz to 40kHz |
| Rated Power | 20mW |
| Impedance | 32Ω |
| Sensitivity | 99dB +/- 3dB at 1kHz |
| Chipset | Qualcomm QCC3095 |
| Bluetooth | Bluetooth 6.0 |
| Bluetooth Profiles | A2DP, AVRCP, HFP, HSP, SPP |
| Supported Codecs | SBC, AAC, aptX, aptX HD, LDAC |
| Wireless Range | 10m |
| Noise Control | Active Noise Cancellation and Transparency Mode |
| Microphones | Six-microphone design |
| Battery | 600mAh full self-replaceable battery |
| Playback | 35+ hours with ANC on, 50+ hours with ANC off |
| Charging Time | Under 1.5 hours |
| App Support | Noble FoKus app with EQ, OTA updates, and multi-language support |
| Water Resistance | IP52 |
| MSRP | $899 USD |
