Noble Audio
Noble Audio FoKus Apollo Wireless Headphones - Open Box
Regular price $499
Sale price $499 Regular price $649.00
Save 23%
1 of 10
Noble Audio
Regular price $499
Save 23%
Wireless, Wired
All Open box Noble Audio FoKus Apollo Headphones are tested, inspected and cleaned by our meticulous returns team and sold in like-new condition with their original packaging and accessories.
Introducing the Noble Audio FoKus Apollo, a revolutionary step into the world of wireless over-ear headphones. As Noble Audio's first over-ear model, the FoKus Apollo features the world's first patented hybrid dual driver arrangement, combining a 40mm dynamic driver with a 14.5mm planar magnetic driver. This unique combination delivers an unparalleled audio experience, blending powerful bass with delicate, crystal-clear mid and high frequencies.
Advanced Wireless Technology
The Noble Audio FoKus Apollo is equipped with the latest Bluetooth 5.3 technology, providing a seamless and stable connection. With support for multipoint connection, you can easily switch between devices without any interruptions. Enjoy lossless audio quality with a range of supported codecs, including LDAC, AAC, aptX, and aptX HD, ensuring that your music sounds its best no matter what device you're using.
Unmatched Battery Life
Experience the freedom of extended listening with the best battery life on the market. The FoKus Apollo offers up to 80 hours of playtime with ANC off at 50% volume and up to 60 hours with ANC on. Whether you're on a long flight or a busy day at work, these headphones are designed to keep up with your lifestyle, providing uninterrupted high-quality sound.
Superior Build and Comfort
Crafted with premium materials, the FoKus Apollo features an anodized aluminum frame and memory foam Korean Protein leather earpads, ensuring durability and comfort. The earpads are replaceable, extending the lifespan of your headphones and maintaining a comfortable fit. The Alcantara headband adds a touch of luxury, making the FoKus Apollo a pleasure to wear for extended periods.
Advanced Noise Cancellation
The FoKus Apollo utilizes hybrid ANC technology with the QCC3084 chip, incorporating three microphones per side for superior noise reduction up to -35dB. This advanced ANC system uses both feedforward and feedback microphones to cancel out ambient noise more effectively, allowing you to immerse yourself in your music without distractions. Additionally, the transparency mode lets you stay aware of your surroundings when needed.
Versatile and Practical Features
Designed for both office and gaming use, the FoKus Apollo comes with a detachable boom mic featuring a mute switch for clear communication. The six integrated microphones ensure exceptional voice clarity, whether you're on a call or recording a podcast. With multiple wired connection options, including USB-C, 3.5mm auxiliary cable, and a wired airplane adapter, you have the flexibility to connect to a wide range of devices.
Specification Details
Driver Arrangement Hybrid Dual Driver: 40mm dynamic driver + 14.5mm planar magnetic driver
Bluetooth Version 5.3
Multipoint Connection Yes
Supported Codecs LDAC, AAC, aptX, aptX HD
Battery Life (No ANC) Up to 80 hours (50% volume)
Battery Life (With ANC) Up to 60 hours (50% volume)
Active Noise Cancellation -20dB to -35dB reduction
Chip QCC3084 with Ultra-Low-Power ANC
Frame Material Anodized Aluminum
Earpads Memory foam Korean Protein leather, replaceable
Number of Microphones 6
Detachable Boom Mic Included, with mute switch
Additional Features Transparency Mode, Noble FoKus App Compatibility
What's Included
  • Noble Audio FoKus Apollo Wireless Headphones with ANC
  • EVA Carrying Case
  • 3.5mm Auxiliary Cable
  • USB-C Cable
  • Two-Prong Airline Adapter
  • 6.3mm Adapter for Headphone Amps
  • Detachable Boom Mic
Experience the future of wireless audio with the Noble Audio FoKus Apollo, available now at Headphones.com. Whether you're an audiophile, a professional, or a gamer, these headphones offer the perfect blend of advanced technology, superior sound quality, and luxurious comfort.
