Meze
Meze Audio Boom Mic
Meze Audio Boom Mic
Meze Audio Boom Mic
The Meze Audio Boom Mic is a detachable omnidirectional microphone designed to turn compatible headphones into a high-quality gaming or work headset. Built for clear communication and everyday reliability, it delivers natural voice reproduction with precise pickup for gaming, streaming, and remote work.
Crafted with premium materials and thoughtful ergonomics, the Boom Mic reflects Meze’s design philosophy, combining durable construction, flexible positioning, and convenient in-line controls for a clean and practical setup.
Key features
- Omnidirectional condenser microphone for natural voice capture
- Detachable boom design for gaming and professional use
- CNC milled and laser-engraved aluminum microphone housing
- Flexible and malleable arm for precise mic positioning
- In-line mute switch and rotary volume control
- Wired connection with no batteries required
Use case and performance
Designed for gamers and remote professionals, the Boom Mic delivers clear and accurate voice reproduction without latency or compression artifacts associated with wireless solutions. The omnidirectional pickup captures speech evenly from all angles, producing a natural and intelligible sound profile for team communication, streaming, and video calls.
Due to the nature of omnidirectional microphones, the Boom Mic performs best in quiet environments or when paired with software-based noise reduction. This design choice prioritizes vocal realism and clarity over aggressive isolation.
Compatibility
The Boom Mic is compatible with headphones featuring dual mono 3.5 mm inputs and with devices using a CTIA 3.5 mm jack. An included Y-adapter allows use with separate headphone and microphone inputs.
Technical specifications
| Microphone type | Condenser |
| Polar pattern | Omnidirectional |
| Microphone sensitivity | -44 ±3 dB |
| Connector standard | 3.5 mm (1/8”) jack, CTIA compatible |
| Frequency response | 100 Hz to 10 kHz |
| Cable length | 2.5 m / 8.2 ft |
What’s in the box
- Meze Audio Boom Mic detachable microphone
- 3.5 mm (1/8”) Y-adapter
- PU leather pouch
