KEF
KEF Q3 Meta Bookshelf Speakers
Regular price $899.99
Sale price $899.99 Regular price $899.99
1 of 3
KEF
The KEF Q3 Meta Bookshelf Speakers, now available at Headphones.com, present an incredible leap forward in sound quality for music lovers and home theater enthusiasts. Designed as the mid-sized model in KEF’s updated Q Series, these versatile bookshelf speakers deliver pristine audio clarity and sumptuous detail. They effortlessly fill your room with rich sound, handling everything from subtle acoustic tunes to high-impact cinematic scores with exceptional depth, accuracy, and finesse.
Cutting-Edge Uni-Q Driver Array for Expanded Soundscapes
Central to the KEF Q3 Meta’s remarkable performance is their innovative 12th generation Uni-Q driver array. This state-of-the-art design places the tweeter within the midrange driver, aligning all frequencies into a single point source. The result is a truly immersive and cohesive audio experience, ensuring that every listener, regardless of seating position, is treated to a spacious and enveloping soundstage.
Advanced Metamaterial Absorption Technology (MAT) for Crystal-Clear Highs
Incorporating KEF’s pioneering Metamaterial Absorption Technology, the Q3 Meta Bookshelf Speakers excel at producing crystal-clear highs free from distortion or harshness. The metamaterial absorber, strategically positioned behind the tweeter, absorbs up to 99% of unwanted sound, ensuring the treble remains pure and controlled. This ground-breaking technology lets the nuances of your favorite tracks emerge, revealing subtleties you may have never heard before.
Precision-Engineered Crossover and Bass Reflex Cabinet Design
The KEF Q3 Meta Bookshelf Speakers employ meticulously tuned crossovers, informed by over a thousand detailed measurements taken in KEF’s UK facilities. Combined with a well-crafted bass reflex cabinet and a rear-firing flared port, these speakers deliver tight, controlled bass that complements the midrange and treble frequencies perfectly. Whether it’s the subtle resonance of a double bass or the rumble of a blockbuster movie soundtrack, the Q3 Meta ensures that every low-frequency note is reproduced with superb accuracy.
Thoughtful Aesthetics and Placement Flexibility
Beyond their audio capabilities, the KEF Q3 Meta speakers feature a sleek and contemporary design that seamlessly integrates with any interior décor. Their compact footprint and included port plugs make it easy to position these speakers in challenging environments. Whether you place them on dedicated stands or add them to a media console, you’ll be able to customize your speaker arrangement for the best possible sound in your space.
Seamless Integration into Your Existing Setup
These versatile bookshelf speakers aren’t just ideal for dedicated stereo listening; they also integrate effortlessly into multichannel systems, making them an excellent choice for expanding or upgrading your current home theater configuration. Adding a KEF Kube powered subwoofer or pairing them with other Q Series models can dramatically enhance the overall sound quality, providing a truly complete and immersive listening experience.
Long-Lasting Build Quality and Peace of Mind
Crafted with a commitment to long-term reliability, the KEF Q3 Meta Bookshelf Speakers are built to deliver a lifetime of enjoyment. From their durable cabinet construction to their high-quality drivers, these speakers represent a genuine investment in sound. Backed by KEF’s generous warranty and supported by the trusted expertise of Headphones.com, you can be confident in the enduring quality of your purchase.
Enclosure Ported
Finish MDF/Wood-grain vinyl
Color White
Tweeter Type Hard-Dome
Tweeter Size (inches) 1
Midrange Size (inches) N/A
Woofer Size (inches) 6.5
Woofer Composition Aluminum
Woofer Surround Rubber
Power Range 10-150
Sensitivity 87 dB
Impedance (Ohms) 4
Frequency Response 49-20k Hz
Connector Type Binding Post
Bi-amp Inputs No
Height (inches) 14-1/16
Width (inches) 8-5/16
Depth (inches) 12-7/16
Weight (pounds) 18.1
Wall-mountable No
Bracket Included No
Recommended Stand Height (inches) 18-24
Parts Warranty 5 Years
Labor Warranty 5 Years
What’s in the Box:
  • (2) KEF Q3 Meta Bookshelf Loudspeakers
  • (2) Grilles
  • (2) Foam Port Plugs
  • (8) Self-Adhesive Rubber Feet
  • Owner's Manual
  • Warranty Information
  • Online Registration Card
  • "Environmental Labeling of Packaging" Sheet
