Hisenior Audio
Hisenior Mega7 In-Ear Headphones
Regular price $449
Sale price $449 Regular price $449.00
1 of 10
Hisenior Audio
Regular price $449
The Hisenior Mega7 is a 7-driver hybrid in-ear monitor built around one clear idea: balanced sound that stays faithful to the original recording. Sitting in Hisenior’s flagship Mega series after the Mega5P and Mega5EST, the Mega7 continues the brand’s “Ultimate Balanced Sound” philosophy with a tuning that aims for deep sub-bass, a natural midrange, and smooth, extended treble.
At $449.00, the Mega7 is designed as an effortless everyday companion for listeners who want a clean, studio-minded presentation without giving up musicality. Its hybrid driver system combines a new 10mm dual-cavity bio-cellular diaphragm dynamic driver with six balanced armature drivers from Sonion and Knowles, all organized through a 4-way crossover and 4-sound-tube acoustic design.
Balanced Sound, Built for Real Listening
The Mega7 is tuned to sound clean, coherent, and easy to trust. Its low end reaches deep with strong sub-bass presence, while the midrange stays natural and even for vocals, instruments, and the body of the mix. Treble is extended smoothly rather than pushed into sharpness, giving the Mega7 a presentation that feels detailed without becoming fatiguing.
This makes the Mega7 a strong fit for listeners who want an IEM that works across genres without constantly calling attention to one part of the frequency range. It is not trying to be a basshead set, a treble showcase, or a hyper-colored fun tuning. The appeal is balance, separation, and a faithful presentation that makes it easy to keep listening.
7-Driver Hybrid Configuration
The Hisenior Mega7 uses a hybrid 7-driver layout with one dynamic driver and six balanced armature drivers. Bass is handled by a new 10mm dual-cavity bio-cellular diaphragm dynamic driver, designed to deliver stronger low-frequency extension, better control, and improved efficiency. The dual-cavity structure gives the bass driver more working space, helping the Mega7 produce low-end weight without losing speed or definition.
Midrange and treble are handled by a carefully selected balanced armature array using Sonion and Knowles drivers. The driver configuration includes one low driver, two mid drivers, two mid-high drivers, and two super-high drivers, giving the Mega7 a clear division of labor across the frequency range. This helps preserve clean separation, stable imaging, and a more organized presentation with complex music.
DE537R Sound System
The DE537R sound system is Hisenior’s integrated acoustic and driver architecture for the Mega7. It combines the 10mm dynamic driver with Sonion 37AP and E50 balanced armature drivers, plus dual Knowles RAB drivers, all arranged through a 4-way passive crossover and 4 dedicated sound tubes.
That 4-way, 4-sound-tube structure matters because it allows each driver group to operate in its intended range with better separation and control. Instead of forcing all drivers into one crowded acoustic path, the Mega7 uses detailed tuning and physical sound channels to help maintain clarity from sub-bass through upper treble.
APRM Air Pressure Release Mechanism
The Mega7 includes Hisenior’s APRM, or Air Pressure Release Mechanism, which is designed to reduce pressure buildup inside the ear during extended listening. By combining the open-air dynamic driver design, sound tube layout, and cavity air exchange structure, APRM helps improve comfort while preserving the isolation expected from an in-ear monitor.
For long sessions, this makes a real difference. Pressure buildup can make IEMs feel closed-in or fatiguing over time. APRM helps the Mega7 feel more comfortable and more relaxed, which fits the product’s goal of being a balanced, everyday in-ear monitor that can handle hours of listening.
Orca Cable and USB-C Adapter Included
The Mega7 includes Hisenior’s 4-wire Orca cable, made from 6N-UPOCC copper litz conductors. The cable is designed for low resistance, clean signal transmission, and daily flexibility, with a 4.4mm balanced termination for use with compatible DAPs, DAC/amps, and portable sources.
Current Mega7 packages also include the Orca 4.4mm to USB-C adapter, making it easier to use the Mega7 directly with modern phones, tablets, and computers that support USB-C audio. That gives the Mega7 a more complete out-of-the-box setup for both portable and desktop listening.
Key Features
  • 7-driver hybrid in-ear monitor with 1 dynamic driver and 6 balanced armature drivers
  • New 10mm dual-cavity bio-cellular diaphragm dynamic driver for bass
  • Sonion and Knowles balanced armature drivers for mids, mid-highs, and super-highs
  • DE537R sound system with 4-way crossover and 4 dedicated sound tubes
  • Balanced tuning designed to stay faithful to the original recording
  • Deep sub-bass response with natural midrange clarity and smooth treble extension
  • APRM air pressure release mechanism for improved long-session comfort
  • Premium 4-wire Orca 6N-UPOCC copper litz cable included
  • 4.4mm balanced connection for compatible portable and desktop sources
  • Orca 4.4mm to USB-C adapter included with current packages
  • Multiple silicone and foam ear tips included for fit and sound adjustment
  • Manatee leather carry case included
Technical Specs
Product Type Universal in-ear monitor
Price $449.00
Driver Configuration 1 dynamic driver + 6 balanced armature drivers
Driver Details 1 x 10mm dynamic driver, 4 x Sonion balanced armatures, 2 x Knowles balanced armatures
Configuration 1 low, 2 mids, 2 mid-highs, 2 super-highs
Bass Driver 10mm dual-cavity bio-cellular diaphragm dynamic driver
Sound System DE537R with 4-way crossover and 4 sound tubes
Tuning Structure 4-way passive crossover, 4 sound tubes, 4 dampers
Frequency Response 10Hz to 40kHz
Sensitivity 103dB/mW
Impedance 21Ω
Isolation -20dB
Cable Orca 4-wire 6N-UPOCC copper litz cable
Cable Construction 112-core coaxially shielded conductors, 24AWG, ultra-soft PVC insulation
Plug 4.4mm gold-plated brass plug
Warranty 1 year, IEM only
What’s in the Box
  • Hisenior Mega7 in-ear monitors
  • Orca cable
  • Balance silicone ear tips (S, M, L)
  • Smooth silicone ear tips (S, M, L)
  • Foam ear tips, 2 pairs
  • Cable clip
  • Cleaning wiper
  • Leather cable tie
  • User manual
  • Warranty card
  • QC card
