Hifiman
Hifiman Ananda Unveiled Headphones
Regular price $479
Sale price $479 Regular price $549.00
Save 13%
1 of 8
Hifiman
On sale
Regular price $479
Save 13%
Removing the Veil
The Ananda Unveiled introduces technology first seen in the 2024 Susvara Unveiled: eliminating the grille structure that reflects and refracts sound back into the diaphragm. By removing these obstructions, the Unveiled design aims to deliver a purer, more transparent presentation than previous Anandas.
Open, Unfiltered Sound
Traditional mesh grilles can reflect or scatter sound waves, interacting with the ultra-thin diaphragm and creating subtle distortion. HIFIMAN’s Unveiled system removes that layer, producing a more direct, uncolored wavefront. The result: a sense of openness and clarity closer to what the driver itself is capable of.
Enhanced Magnet System
The Ananda Unveiled employs a precisely shaped magnet array that reduces distortion without losing control or dynamics. It’s designed for sensitivity comparable to rare-earth systems while minimizing reliance on those materials.
Second-Generation Supernano Diaphragm
The diaphragm is now ~60% thinner than the original, allowing faster transient response and greater detail retrieval. This change helps the Unveiled keep up with dense mixes and high-resolution recordings while maintaining HIFIMAN’s planar speed and texture.
Comfort and Practical Updates
A Gen. 2 composite headband trims weight (15.8 oz / ~448 g), while rotatable hinges improve seal and long-term wear. The dual 3.5 mm connectors angle outward for durability and ease of cable swaps. Magnetic protective veils fit over the cups when not in use, shielding the open drivers.
Compare the Hifiman Ananda and Arya Lineup
Feature Ananda Unveiled Ananda Stealth Arya Stealth
Type Open-back planar Open-back planar Open-back planar
Frequency Response 5 Hz – 55 kHz 8 Hz – 55 kHz 8 Hz – 65 kHz
Impedance 22 Ω 27 Ω 32 Ω
Sensitivity 93 dB ~92 dB ~94 dB
Weight 15.8 oz (≈448 g) ~440 g ~404 g
Unique Features Unveiled grille-free design, magnetic protective veils Stealth magnets, traditional grille Stealth magnets, larger driver, wider stage
Who it suits Listeners who want maximum transparency and minimal acoustic obstruction Fans of the Ananda tuning who prefer smoother treble and efficient drive Those chasing a wider soundstage and stronger imaging performance
Hifiman Ananda Unveiled Technical Specifications
Specification Details
Type Open-back, planar magnetic
Impedance 22 Ω
Sensitivity 93 dB
Weight 15.8 oz (≈448 g, excluding veils & cable)
Diaphragm NEO Supernano Diaphragm Gen. 2 (≈60% thinner vs Gen. 1)
Magnet Design Precision-shaped permanent magnet system
Headband Composite Gen. 2, rotatable hinges
Cup Connectors Dual 3.5 mm (angled)
What’s in the Box
  • HIFIMAN Ananda Unveiled Planar Magnetic Headphones
  • Magnetic protective veils (pair)
  • Detachable dual 3.5 mm headphone cable
  • 6.35 mm (1/4") adapter
  • User manual & warranty card
Frequently Asked Questions
What does “Unveiled” mean in the Ananda Unveiled?
HIFIMAN removed the traditional grille structure that can reflect and refract sound waves back into the diaphragm. The “Unveiled” design minimizes these interactions, delivering a more transparent and direct sound compared to previous Ananda models.
How does the Ananda Unveiled differ from the Ananda Stealth?
The Ananda Stealth uses stealth magnets with a grille structure, while the Unveiled eliminates the grille entirely. This makes the Unveiled more open and transparent, though it also requires careful handling as the drivers are fully exposed. The Unveiled also ships with protective magnetic veils to shield the drivers when not in use.
Does the Ananda Unveiled need an amplifier?
With a sensitivity of 93 dB and impedance of 22 Ω, the Ananda Unveiled can be powered by high-quality portable DAC/amps, but it performs best with a dedicated desktop amplifier that can deliver strong voltage and current. Pairing with amps capable of 1–2 Vrms or more is recommended for full dynamics.
If you want to know more about power requirements, check out our Headphone Power Calculator.
What are the Magnetic Veils used for on the Ananda Unveiled?
The veils are protective covers that attach magnetically over the earcups when the headphones are not in use. They reduce magnetic absorption from nearby objects and protect the fully open drivers from dust and accidental contact.
How comfortable are the Ananda Unveiled?
At 15.8 oz (≈448 g), the Unveiled is relatively lightweight for a planar magnetic headphone. The Gen. 2 composite headband with rotatable hinges improves fit across different head shapes, and the ear pads are designed for long listening sessions.
What is included in Ananda Unveiled box?
HIFIMAN Ananda Unveiled headphones, detachable dual 3.5 mm cable, 6.35 mm (1/4") adapter, magnetic protective veils, and a user manual/warranty card.
If you are looking for a replacement from the stock cable, check out our in-house Listenmore Etched Headphone Cable that has 3.5mm, 6.35mm, 4-Pin XLR and 4.4mm terminations.
What is the warranty and return policy for the Ananda Unveiled?
The Ananda Unveiled comes with a standard HIFIMAN manufacturer’s warranty (One year).
Purchases from Headphones.com are also covered by our 365-day return policy, with customers responsible for return shipping but no restocking fees. Read more about our 365-Day Return policy here.
