HEDD Audio
HEDD Audio HEDDphone TWO GT UNPLUGGED Edition
Regular price $1,699
Sale price $1,699 Regular price $2,199.00
Save 23%
1 of 5
HEDD Audio
On sale
Save 23%
Warm AMT luxury, cable optional
AMT
A richer, smoother take on the HEDD sound
HEDDphone TWO GT UNPLUGGED is voiced for music enjoyment first. It keeps the technical foundation of HEDDphone TWO, then adds a warmer tuning and refined driver design for a more relaxed but still highly detailed presentation. The GT version emphasizes tone, texture, and long term comfort, making it a strong choice for listeners who spend hours in front of a dedicated system.
UNPLUGGED keeps the headphone and carry case only. Cables are left to the listener, which is ideal if you already use specific terminations or balanced runs with other headphones. You still get the full handcrafted AMT driver, Berlin assembly, and five year warranty.
AMT with lower distortion and warmer tuning
TWO GT uses a redesigned Air Motion Transformer with a multi layered Kapton polyimide diaphragm. The updated driver reduces distortion and works with Variable Velocity Transformation to keep the response even from 10 Hz to 40 kHz. Compared to the standard TWO, the GT tilts slightly warmer while keeping speed and resolution intact.
Comfort focused for listening sessions
The GT version retains the carbon fibre and magnesium structure and the adjustable HEDDband system. The UNPLUGGED model ships with velour pads that balance comfort and acoustic seal, helping the headphone disappear during long playlists.
Pair it with Listenmore
Since no cable is included with HEDDphone TWO GT UNPLUGGED, we recommend pairing it with a Listenmore Etched Headphone Cable. These cables are light, flexible, and offered with terminations such as 6.35 mm, 4.4 mm, and XLR, so you can match the GT to your amplifier and rack without extra adapters.
Key Features
  • Warm, refined tuning based on HEDDphone TWO
  • Redesigned AMT driver with multi layered Kapton polyimide diaphragm
  • Variable Velocity Transformation for even response from 10 Hz to 40 kHz
  • Velour ear pads tuned for long term comfort
  • Adjustable HEDDband with control over height, width, curvature, and clamp
  • Carbon fibre and magnesium structure for strength and reduced weight
  • Handmade and assembled in Berlin
  • Five year warranty after registration
  • Supplied without a cable for users who prefer their own
Specification Details
Design Open back, over ear
Driver Air Motion Transformer with VVT and multi layered Kapton polyimide diaphragm
Frequency Range 10 Hz to 40 kHz
Maximum SPL 88 dB SPL at 1 mW
Impedance 41 ohms flat
Recommended Power Minimum 200 mW, at least 1000 mW recommended
Input Connector Dual 3.5 mm jacks on the ear cups, cable not included
Ear Pads Velour ear pads and head cushion
Weight 550 g
Cable Not included. Compatible with dual 3.5 mm headphone cables
Warranty Five years after registration
What is in the box
  • HEDDphone TWO GT UNPLUGGED headphones
  • Velour ear pads installed
  • Protective carry case
  • User documentation
  • No cables included
  • No extra ear pads included
