Ferrum Audio
Ferrum Hypsos Dual Output Power Supply
Regular price $1,595
Sale price $1,595 Regular price $1,395.00
1 of 2
Ferrum Audio
Linear/Switching Hybrid Power Supply
Revolutionary Dual Output Power Solution for Audiophile Systems
Unlock the full potential of your audio equipment with the Ferrum Hypsos Dual-Output Linear/Switching Hybrid Power Supply. This groundbreaking hybrid design uniquely blends the rapid transient response of switching power supplies with the ultra-low noise and impedance characteristics of linear power solutions. The Hypsos is not merely an accessory—it's a transformative audio component capable of dramatically elevating your system's performance.
Precision Voltage Control and Customization
Engineered for exceptional versatility, the Ferrum Hypsos provides a continuously adjustable output voltage range from 5 to 30 volts with a maximum current of 6 amps. Its innovative Sweet Spot Tuning (SST) allows you to fine-tune the voltage precisely, even during operation, enabling real-time optimization of audio performance. This precise control helps to deliver a clearer, richer, and more detailed soundstage tailored exactly to your preferences.
Advanced 4-Terminal Sensing Design
The Ferrum Hypsos features an advanced 4-Terminal Sensing Design (4TSD), ensuring exact voltage delivery directly at your device’s DC input. By significantly reducing voltage fluctuations caused by cable resistance, this technology markedly improves transient response, clarity, and dynamic range. Enjoy audio reproduction that is consistently smooth, stable, and free from distortions caused by power supply inefficiencies.
Unmatched Safety and Seamless Integration
Built with comprehensive safety features, including Automatic Transformer Voltage Adjust (ATVA), electronic output voltage polarity switching, and robust protection against overvoltage, current surges, and short circuits, the Hypsos offers worry-free operation. Its compatibility with Apple TV remotes and trigger in/out connectors facilitates seamless integration into automated setups, effortlessly managing power-up and standby modes to complement your audiophile system's ease of use and convenience.
What's In the Box
  • Ferrum Hypsos Dual-Output Linear/Switching Hybrid Power Supply
  • 0.5m × 2.5 mm DC Plug Cable
  • User Manual
  • Warranty Information
Use one HYPSOS to power any two devices with the same voltage.
*Comes with one 0.5m DC cable; auxiliary output cable must be purchased separately.
