Eversolo
Eversolo DMP-A6 Streamer and DAC - Open Box
Regular price $729
Sale price $729 Regular price $899.00
1 of 5
Eversolo
Regular price $729
A Paradigm of Audio Excellence
Redefining the Streaming Experience
The Eversolo DMP-A6 emerges as an all-in-one DAC and streamer, meticulously crafted for extreme flexibility and lossless playback. With professional audio tuning, it stands as a testament to Eversolo's commitment to revolutionize music streaming.
Cutting-Edge Design and User Interface
Encased in a solid aluminum alloy chassis, the DMP-A6 boasts a 6" LCD color touchscreen. The deeply tailored user interface, based on Android 11, offers an intuitive and responsive experience, ensuring seamless interaction with the device's extensive features.
Unmatched Internal Storage Capabilities
The DMP-A6 takes storage to new heights with support for up to 4TB M.2 NVME 3.0 SSD internal storage. This immense capacity allows audiophiles to house their expansive music libraries within the device, ensuring quick and easy access to their favorite tracks.
Dual DAC Architecture for Pristine Sound
Equipped with dual ESS ES9038Q2M DACs, the DMP-A6 facilitates independent decoding for each channel. This design significantly reduces interference and noise, enhancing the overall clarity, signal-to-noise ratio, and dynamic range of the audio output.
Supports a Wide Range of High-Resolution Formats
The DMP-A6 is capable of decoding various ultra-high resolution audio formats including DSD512 Native, PCM768KHz @32Bit, and MQA. This versatility ensures compatibility with a broad spectrum of audio files, delivering the purest form of the recorded music.
Innovative Technologies for Superior Performance
Incorporating DOH chips for HDMI DSD multichannel and a 3rd Gen XMOS 316 audio processor, the DMP-A6 guarantees high-speed, lossless transmission of Hi-Def audio data. It also features low-jitter, dual clock processing for more accurate and precise audio decoding.
Connectivity and Streaming Services
The DMP-A6 offers super-flexible connectivity options, including USB, Optical, Coaxial, HDMI, Bluetooth, WiFi, and wired ethernet connections. It supports popular music services like TIDAL, Qobuz, HIGHRESAUDIO, Amazon Music, and is capable of streaming via Roon Ready, Air Play, DLNA, Spotify, and Tidal Connect.
Advanced Features for Enhanced Usability
With its fully balanced preamp circuit, premium component selection, and effective media management capabilities, the DMP-A6 is not just a music player but a comprehensive audio system. Its ability to playback and rip CDs, coupled with a smart control app available for both Android and iOS devices, makes it a versatile and user-friendly option for any audiophile.
The Eversolo DMP-A6 stands as a beacon in the world of high-fidelity audio streaming and DAC systems. Its combination of robust storage, advanced decoding capabilities, and extensive connectivity options make it a must-have for anyone seeking an unparalleled audio experience.
EverSolo DMP-A6 Technical Specifications
Model EverSolo DMP-A6
Display 6" LCD touchscreen
Internal Memory 4GDDR4 +32GeMMC
CPU Quad-core ARM Cortex-A55 Pro
DAC (x2) ES 9038Q2M
Audio Processor Gen 3 XMOS XU316
Op-amp Chip OPA1642
SSD M.2 NVME 3.0 2280 protocol, up to 4TB
USB USB-A (3.0) Out | USB-C: Windows, Mac, Android, IOS, Supports DSD512, PCM 768KHz 32Bit, MQA
Ethernet RJ-45 (10/100/1000 GB) | NFS, SMB v1/2/3, UPnP protocols
WiFi 2.4G+5G dual band
Bluetooth BT 5.0, support SBC/AAC/aptX/aptX LL/aptX HD/LDAC
Playback and DAC Decoding DSD512, PCM 768KHz 32Bit, MQA
Music Service Tidal, Qobuz, HighresAudio, Amazon, WebDAV, UPnP
Streaming Roon Ready, Air Play, DLNA, Spotify, Tidal Connect, Qobuz Connect
Optical/Coaxial In/Out Supports PCM 192KHz 24Bit, DSD64 Dop, MQA
HDMI Audio Output DSD64 Native multi-channel/PCM192KHz multichannel raw output (up to 5.1)
Control Method Mobile App, Touch screen control
XLR Output Output level: 5.2V
Frequency response: 20Hz~20KHz (±0.15dB)
Dynamic range: >128dB
SNR: >128dB
THD+N: <0.00009% (-120dB) @A-wt
Crosstalk: >-125dB
RCA Output Output level: 2.6V
Frequency response: 20Hz~20KHz (±0.2dB)
Dynamic range: >124dB
SNR: >124dB
THD+N: <0.00011%(-119dB)@A-WT
Crosstalk: >-124dB
Power Supply AC 110~240V 50/60Hz | low noise, high quality switching
Rated Power 13W
Dimensions 10.6" x 7.4" x 3.5"
