Eversolo
Eversolo DMP-A6 Streamer and DAC Gen 2
Regular price $859
Sale price $859 Regular price $859.00
1 of 5
Eversolo
Regular price $859
A reference streamer built for modern hi-fi systems
Eversolo DMP-A6 Gen 2 Hi-Fi Music Streamer
The Eversolo DMP-A6 Gen 2 is a next generation Hi-Fi music streamer designed for listeners who want reference level sound quality paired with modern usability. From its fully balanced audio architecture to its custom EOS audio engine, every element is engineered to deliver high resolution playback with precision, stability, and flexibility.
Precision Aluminum Construction
The chassis is machined from a single piece of aerospace grade aluminum using high precision CNC processes. This rigid construction improves durability while reducing external interference that can affect audio performance. The refined matte finish adds a clean, modern look that fits easily into high end audio systems.
Large Touchscreen Interface
A high resolution touchscreen provides direct access to playback, settings, and library management. Navigation is fast and intuitive whether you are browsing local files, adjusting system parameters, or controlling streaming services.
Ultra Low Noise Linear Power Supply
The upgraded linear power supply operates with noise levels below 40 microvolts, providing a stable and clean power source for the entire audio circuit. This contributes to a lower noise floor, improved clarity, and more consistent performance across all outputs.
Fully Balanced Audio Architecture
From decoding through output, the DMP-A6 Gen 2 uses a fully balanced circuit design. Balanced XLR and unbalanced RCA outputs are both available, allowing easy integration with power amplifiers, active speakers, or headphone amplifiers while maintaining excellent dynamic range and low distortion.
Dual ES9038Q2M DAC Design
Two ES9038Q2M DAC chips are used in a true dual mono configuration, with each chip independently processing one channel. This design improves channel separation, dynamic range, and detail retrieval, allowing complex recordings to be reproduced with accuracy and depth.
Advanced Digital Processing
The third generation XMOS XU316 audio interface provides significantly increased processing power and supports PCM up to 768kHz at 32-bit and native DSD512. Dual high precision clock oscillators and low jitter synchronization ensure stable timing and accurate signal reproduction.
EOS Audio Engine and EVC Volume Control
Eversolo’s self-developed EOS audio engine bypasses SRC limitations to preserve original signal integrity. The EVC output engine uses a precision volume adjustment algorithm that maintains waveform accuracy at all gain levels, ensuring the DAC receives complete and unaltered audio information.
Comprehensive Format and Streaming Support
The DMP-A6 Gen 2 supports a wide range of formats including DSD, MQA, FLAC, APE, and WAV. Deep integration with streaming services such as TIDAL, Qobuz, Apple Music, and others allows high resolution direct output through the EOS engine. Roon Ready and TIDAL Connect support make integration into existing ecosystems seamless.
Local Library and Storage Expansion
Music files can be added from USB drives, network storage, or internal SSD expansion via the M.2 NVMe slot supporting up to 4TB. The system automatically organizes music by artist, album, genre, and metadata, creating a unified and searchable library.
Connectivity and System Integration
HDMI ARC allows direct TV audio input, while HDMI multichannel output supports up to 5.1 playback for compatible systems. Bluetooth 5.0 provides convenient wireless input, and TRIGGER plus Wake-on-LAN features enable seamless system automation and remote power control.
Display 6-inch LCD touchscreen
DAC Dual ES9038Q2M
Audio Processor XMOS XU316
Memory 4GB DDR4 + 32GB eMMC
Internal Storage Expansion M.2 NVMe SSD up to 4TB
Analog Outputs XLR balanced, RCA unbalanced
XLR Output Level 5.2V
RCA Output Level 2.6V
Digital Inputs USB-B, Optical, Coaxial, HDMI ARC
Digital Outputs USB, Optical, Coaxial, HDMI
Wireless WiFi dual-band, Bluetooth 5.0 SBC AAC
Streaming Roon Ready, DLNA, TIDAL Connect
Supported Formats PCM up to 768kHz 32-bit, DSD512, MQA
Power Supply Low noise linear power supply
Rated Power Consumption 13W
Dimensions 7.4 x 10.6 x 3.5 inches
What’s in the Box
  • Eversolo DMP-A6 Gen 2 music streamer
  • Power cable
  • USB data cable
  • Trigger cable
  • User manual
FAQ
Does the DMP-A6 Gen 2 support Roon?
Yes. It is fully Roon Ready and integrates directly into Roon systems.
Can I install internal storage?
Yes. The built in M.2 NVMe slot supports SSDs up to 4TB for local music storage.
Is this suitable as a standalone preamp?
Yes. With balanced and unbalanced pre outputs and precision volume control, it can be connected directly to power amplifiers or active speakers.
Does HDMI ARC work with TVs?
Yes. HDMI ARC allows direct TV audio playback through the DMP-A6 Gen 2.
Can it wake remotely?
Yes. Wake-on-LAN is supported when connected via wired Ethernet.
