ELAC
ELAC NAVA 100 Portable Bluetooth Speaker
Wireless
Portability
The ELAC NAVA 100 is a compact portable Bluetooth speaker designed for listeners who value balanced sound, refined industrial design, and everyday usability. Built around a single 3 inch full-range driver with dual passive bass radiators, NAVA 100 delivers surprising depth and clarity from a small aluminum enclosure. With Bluetooth 5.3 connectivity, built-in amplification, and a rechargeable battery, it is an easy, self-contained solution for high quality listening at home or on the go.
Key Features
- One 3 inch full-range paper cone driver with dual passive bass radiators
- 10 watts RMS of built-in amplification
- Bluetooth 5.3 wireless music streaming with SBC support
- Dual Play mode for true wireless stereo pairing with a second NAVA 100 speaker (sold separately)
- Solid aluminum exterior with soft-touch control buttons
- Built-in rechargeable battery with USB-C charging
Sound and Use Case
NAVA 100 is tuned for detailed, balanced playback rather than exaggerated loudness. The full-range driver keeps vocals and instruments cohesive, while the passive radiators add low frequency weight that exceeds expectations for its size. This makes NAVA 100 well suited for desk listening, kitchens, bedrooms, patios, and travel where clarity and tonal balance matter more than sheer output.
Dual Play mode allows two NAVA 100 speakers to be paired wirelessly for stereo playback. One speaker automatically handles the left channel and the other the right, creating a wider soundstage and a more immersive listening experience without cables or setup complexity.
Design and Controls
The enclosure is constructed entirely from aluminum, including the grille and rear panel, giving the speaker a solid, premium feel and improved resonance control compared to plastic housings. Soft-touch buttons on the top panel provide direct access to Bluetooth pairing, playback, volume control, and power without relying on an app.
| Speaker Type | Portable Bluetooth speaker |
| Driver Configuration | One 3 inch full-range driver with two passive bass radiators |
| Driver Type | 3 inch paper cone full-range |
| Amplification | 10 watts RMS |
| Frequency Response | 55 Hz to 19.6 kHz (-10 dB) |
| Bluetooth Version | Bluetooth 5.3 (SBC supported) |
| Stereo Pairing | Yes, Dual Play mode |
| Wi-Fi | No |
| Apple AirPlay | No |
| Hands-Free Calling | No |
| Audio Inputs | None |
| Charging Port | USB-C |
| Charging Time | 4 to 5 hours standard or 2 hours with 1.5A charging |
| Battery Life | Up to 15 hours at 25% volume or up to 6 hours at 100% volume |
| Enclosure Material | Aluminum |
| Color | Black |
| Dimensions (W x H x D) | 5.9 x 5.04 x 3.07 inches |
| Weight | 3.08 lbs |
| Warranty | 1 year parts and 1 year labor |
What’s in the Box
- ELAC NAVA 100 portable Bluetooth speaker
- 12 inch USB-C to USB-A charging cable
- Quick Start Guide
- Owner’s manual
