ELAC
ELAC Debut 3.0 DB53 5.25" Passive Bookshelf Speaker - Pair
Regular price $399
Sale price $399 Regular price $399.00
1 of 9
ELAC
Regular price $399
The ELAC Debut 3.0 series is built to bring ELAC’s acoustic legacy into approachable systems with a more refined look and carefully updated driver technology. The Debut 3.0 DB53 is a compact 2-way bass reflex bookshelf speaker designed for stereo and surround sound setups, combining a newly developed aramid fiber mid-bass woofer with a calibrated 1 inch aluminum dome tweeter. A braced MDF cabinet, dual flared rear porting, and magnetically attached grilles help deliver clean sound with a modern, hardware-free appearance.
Key Features
  • 2-way bass reflex bookshelf speaker design for stereo or surround applications
  • 1 inch aluminum dome tweeter calibrated for clarity, detail, and wide dispersion
  • 5.25 inch woven aramid-fiber cone mid-woofer for tight, controlled bass with low distortion
  • Internally braced cabinet to reduce resonances and cabinet coloration
  • Magnetically attached removable cloth grilles for a clean, hardware-free front look
  • Dual flared rear-firing port design intended to enhance low frequencies and reduce distortion
  • 5-way metal binding posts for standard speaker cable connections
  • Easy to drive design intended to work well with a wide range of amplifiers
Sound and Use Case
DB53 is designed for balanced listening with a focus on clarity and control in a compact bookshelf form factor. The aluminum dome tweeter is built for clean high-frequency detail and consistent coverage across the listening area, while the aramid-fiber mid-woofer is engineered for punchy, well-defined low frequencies. Internal bracing helps keep the cabinet quieter so the sound you hear is driven by the drivers rather than enclosure vibration.
Use DB53 as a pair for music listening in small to mid-size rooms, or as part of a multi-channel home theater system. With a 6 ohm nominal impedance and 86.5 dB sensitivity, DB53 is intended to reach satisfying levels with modest amplifier power.
Model ELAC Debut 3.0 DB53
Speaker Type 2-way, bass reflex
Frequency Response 42 Hz to 38 kHz
Frequency Response (-6 dB) 42 Hz to 38 kHz
Frequency Response (-3 dB) 70 Hz to 34 kHz
Nominal Impedance 6 Ω
Minimum Impedance 4.8 Ω at 200 Hz
Sensitivity 86.5 dB (2.83 V/1 m)
Crossover Frequency 1900 Hz
Recommended Amplifier Power 20 to 120 W per channel
Nominal and Peak Power Handling 120 W
Power Handling 50 W RMS per channel, 70 W peak per channel
Tweeter 1 inch aluminum dome
Mid-Woofer 5.25 inch woven aramid-fiber cone
Cabinet CARB2 rated 16 mm MDF
Cabinet Finish Black Ash Vinyl, Satin Black Vinyl Front
Enclosure Ports 1 rear-firing port per speaker, dual flared
Binding Posts 5-way metal
Grille Removable cloth grille, magnetic attachment
Placement Tabletop or bookshelf (with included hardware)
Floor Contacts Adjustable rubber feet
Dimensions (W x H x D) 6.8 x 12.2 x 10.5 inches (172 x 311 x 267 mm) each
Net Weight 13.34 lb (6.05 kg)
Package Weight 31.115 lb
Box Dimensions (L x W x H) 19 x 16.2 x 14.3 inches
Color Black
Environmental Resistance No
What’s in the Box
  • ELAC Debut 3.0 DB53 bookshelf 2-way speakers (black, pair)
  • 4 rubber feet
  • Limited 3-year manufacturer warranty
