ELAC
ELAC DCB61 Debut ConneX 2-Way Active Wireless Bookshelf Speaker - Pair
Wireless
Portability
The ELAC DCB61 Debut ConneX is a 2-way active wireless bookshelf speaker system built to simplify music, TV, and movie playback without giving up real hi-fi performance. With built-in amplification, a wide range of inputs, and app control, DCB61 can serve as a complete entertainment hub for a living room, desktop, or small media space. Dolby Digital support enables cinema-ready 2.1-channel output when paired with an optional subwoofer.
Key Features
- Active 2-way bookshelf speaker system with built-in amplification
- Dolby Digital support for 2.1-channel playback when paired with an optional subwoofer
- HDMI ARC input for simple TV connection
- RCA phono input for turntables
- Optical input for digital sources
- USB-A input for audio playback from compatible sources and USB-B input
- Bluetooth wireless streaming with LC3 codec support
- RCA subwoofer output for easy low-frequency expansion
- XBass enhancer with the option to disable for a more neutral response
- Rear-firing S-shaped bass reflex ports designed to deepen bass while minimizing port noise
- ELAC ConneX mobile app for setup, volume, EQ, placement optimization, and Auto-On control
- Remote control and removable cloth grilles included
Sound and Use Case
DCB61 is designed for balanced sound with strong low-frequency presence from a long excursion 6.5 inch woofer in each speaker. A waveguide tweeter is used to shape dispersion and directivity for clearer, more consistent treble across the listening area. For additional bass extension and output, ELAC’s XBass enhancer can be enabled, or turned off when you prefer a more neutral presentation.
For TV and movies, HDMI ARC provides an easy connection path, and Dolby Digital support allows 2.1 playback when you add a subwoofer to the dedicated output. For music systems, the phono input supports turntables, while optical, USB, and Bluetooth cover common digital sources.
| Model | ELAC Debut ConneX DCB61 |
| Speaker Type | Active wireless bookshelf speakers (pair) |
| Speaker Configuration | 2-way |
| Amplifier Power Rating | 160 W RMS, 320 W peak |
| Drivers | 1 x 6.5 inch woofer per speaker, 1 x tweeter per speaker (waveguide tweeter described) |
| Enclosure Type | Bass reflex |
| Ports | 1 rear-firing port per speaker (S-shaped bass reflex port described) |
| Frequency Response | 48 Hz to 22 kHz (-3 dB), 41 Hz to 24 kHz (-6 dB) |
| Wireless Connectivity | Bluetooth |
| Supported Audio Codecs | LC3 |
| Supported Sample Rates | Up to 96 kHz / 24-bit |
| Inputs | HDMI (ARC), stereo RCA (phono), TOSLINK optical, USB-A (audio), USB-B |
| Outputs | RCA subwoofer output |
| Inter-speaker Connection | Mini-DIN 4-pin thru (to other speaker) |
| Cabinet Material | MDF |
| Finish | Black ash woodgrain |
| Grille | Removable cloth |
| Placement | Tabletop or bookshelf |
| Dimensions (Each) | 5.5 x 8 x 9.6 inches (139.7 x 203.2 x 244.5 mm) |
| Weight | 24.0 lb (10.9 kg) |
| Warranty | Limited 3-year manufacturer warranty (cabinet and speaker driver), limited 1-year manufacturer warranty (amplifier) |
| Package Weight | 32.465 lb |
| Box Dimensions (L x W x H) | 20.1 x 18.1 x 13.4 inches |
What’s in the Box
- ELAC DCB61 Debut ConneX 2-way active wireless bookshelf speakers (black ash, pair)
- Remote control with batteries
- Rubber foot
- Power cord
- Speaker cable
- HDMI cable
- 2 speaker grilles
- Limited 3-year manufacturer warranty (cabinet and speaker driver)
- Limited 1-year manufacturer warranty (amplifier)
