Cambridge Audio
Cambridge Audio DacMagic 200M - Open Box
Regular price $449
Sale price $449 Regular price $549.00
1 of 7
Cambridge Audio
Regular price $449
Wired, Wireless
The Cambridge Audio DacMagic 200M is a jack-of-all trades desktop DAC and Headphone Amplifier that does not compromise. A pair of high-quality ESS Sabre Digital to Audio Convertors make up the guts of of the DacMagic 200M allowing it to handle digital audio files up to 24bit/768kHz or DSD512. In addition to the DacMagic 200M being a phenomenal DAC, it's also a headphone amplifier in addition to having bluetooth aptX connectivity.
Once a digital file is onboard DacMagic 200M, its twin DACs convert it to analogue information with all of its dynamics and detail intact. And, because the analogue signal it sends to your audio set-up is so astonishingly free of distortion, so precise and so lifelike, your system will sound more convincing and complete than it ever has before.
Highlights
  • Dual ESS ES9028Q2M DACs - easily handles digital audio files up to 24-bit/768kHz or DSD512
  • Supports MQA - be sure you're listening to artist-approved studio-quality audio
  • Digital optical, digital coaxial and USB inputs - connect CD players, games consoles, laptops or other digital audio sources
  • Built in Bluetooth aptX - send digital audio files from your smartphone or tablet wirelessly
  • Finished in Lunar Grey
Well connected
It’s possible to get digital audio files into DacMagic 200M in any number of ways. Digital optical, digital coaxial and USB inputs mean CD players, games consoles, laptops or any other digital equipment can be easily hooked up - and Bluetooth aptX reception means it’s just as straightforward to wirelessly deliver files from your smartphone or tablet too.
DacMagic 200M has both balanced and unbalanced analogue outputs, so can be easily connected to audio systems of all types, and switchable filters to give you different sonic options. And as well as its ability to deliver stunning sound to your speakers, it has a high-quality headphone amplifier with 6.3mm output on board too. So you can enjoy DacMagic 200M’s thrilling sound quality in private – at whatever volume you like.
Easy integration
Despite the incredible number of features, the extensive functionality and the extraordinary technology on board the DacMagic 200M, Cambridge Audio has managed to fit it all into a beautifully built, flawlessly finished steel and aluminium box measuring just 52 x 215 x 191mm.
This means it will fit neatly and discreetly into any existing audio set-up without taking up loads of room or drawing too much attention to itself. All that’s required is a balanced or unbalanced connection to your system (and some mains power, of course) for DacMagic 200M to deliver you a sonic upgrade that’s way bigger than the box it comes from.
