Headphones.com
Bluesound Hub
Regular price $379
Sale price $379 Regular price $379.00
1 of 5
Headphones.com
Bluesound Hub
Bluesound Hub
Regular price $379
Revolutionize Your Audio Experience with Bluesound Hub
The Bluesound Hub is a versatile network accessory that transforms any audio system into a multi-room streaming powerhouse. With the ability to connect to a wide array of audio sources, the Hub seamlessly integrates into your existing setup, enhancing the way you experience music.
Stream Without Limits
Streaming audio has never been more flexible. With the Bluesound Hub, wired audio devices can now be part of your multi-room audio setup. This means your cherished CD and vinyl collections can be streamed wirelessly throughout your home, without the constraints of cables or proximity.
Connect and Stream with Ease
The Hub allows you to integrate any wired audio source into your Bluesound ecosystem. By connecting your devices to the Hub, you can breathe new life into your music collection, streaming high-quality audio to every corner of your home.
A New World of Audio Possibilities
Utilize the Hub with a pair of Bluesound Pulse speakers to significantly enhance your TV sound experience. The Hub's five input options - HDMI eARC, Coaxial, Digital Optical, Stereo Analog, and a Moving Magnet Phono stage - support a diverse range of music devices, ensuring compatibility with almost any audio source.
Simultaneous Streaming to Multiple Rooms
With the Hub, play one analog and one digital stream simultaneously to different Bluesound or BluOS players. This feature allows different members of the household to enjoy their preferred music or audio content in various rooms, all from a single, centralized source.
Effortless Control with BluOS App
The BluOS app transforms your smartphone, tablet, or computer into a powerful remote control for your multi-room system. Easily select the Hub as an input and manage your entire audio setup with just a few taps.
Streamlined Design for Flexible Placement
The compact and minimalist design of the Hub, combined with its dual-band Wi-Fi or wired Gigabit ethernet connection options, offers unparalleled placement flexibility. With its external USB-C power supply, the Hub maintains a sleek profile, allowing for discreet integration into any room.
Vinyl Streaming in High-Resolution
For vinyl enthusiasts, the Hub's built-in audiophile-grade MM phono stage preamp is a true delight. It enables high-resolution streaming of vinyl records throughout your home. As a networked phono pre-amp, the Hub ensures low noise and wide bandwidth, delivering exceptional audio quality for a whole-home vinyl listening experience.
In summary, the Bluesound Hub is more than just a network accessory; it's a gateway to a world of audio possibilities. Whether you're streaming vinyl, enhancing TV sound, or exploring digital music collections, the Hub brings unparalleled flexibility and quality to your audio experiences.
