64 Audio
64 Audio Ocean In-Ear Headphones
Regular price $3,999
Sale price $3,999 Regular price $3,999.00
1 of 11
64 Audio
Dynamic, Balanced Armature
Ocean is 64 Audio’s new flagship universal IEM, bringing together the company’s latest driver, acoustic, and tuning technologies in a six-driver, four-way design built around one idea: full-range realism without giving up musicality.
Its hybrid architecture combines a pair of custom dynamic drivers in a cone-to-cone isobaric configuration for the lows, two balanced armatures for the midrange, a dedicated high-mid balanced armature, and a tia™ high driver. The result is what 64 Audio describes as a dynamically neutral presentation, with powerful but controlled bass, a rich and present midrange, natural upper mids, expansive imaging, and effortless high-frequency extension.
Ocean is also one of the most configurable IEMs 64 Audio has produced. Its Passive Acoustic Control system combines interchangeable tia screens, back-vent filters, and Apex modules to create as many as 32 acoustic configurations. That gives listeners meaningful control over treble damping, bass behavior, isolation, pressure relief, and the overall presentation without relying on DSP or electronic EQ.
A Six-Driver Flagship Built as One System
Ocean uses six drivers, but the more important number is four. Its four-way acoustic architecture assigns each section of the frequency range to a purpose-built driver group rather than asking one type of transducer to do everything.
At the bottom are two custom dynamic drivers operating in a cone-to-cone isobaric arrangement. The midrange is handled by two balanced armatures, with another dedicated BA covering the high-mid region where vocals, instruments, and much of our perception of tonal realism take shape. A tia high driver completes the system at the top.
The goal is cohesion rather than simply maximizing driver count. Ocean is designed to preserve separation and spatial definition while still presenting music as a unified whole, giving complex recordings room to expand without pulling individual elements apart unnaturally.
Cone-to-Cone Isobaric Dynamic Bass
Ocean’s low-frequency system uses two dynamic drivers arranged cone-to-cone as an isobaric pair. The configuration is designed to produce deep, powerful bass while maintaining the speed and control expected from a reference-level IEM.
64 Audio describes the resulting low end as exceptionally clean, and that distinction matters. Ocean is built to provide real bass extension and physical authority without allowing the lows to obscure the midrange or compromise spatial information.
The pneumatic loading of the dynamic-driver system can also be altered through Ocean’s interchangeable rear vent filters, making bass behavior part of the IEM’s broader Passive Acoustic Control system rather than a fixed design choice.
Rich Mids and Natural Upper-Mid Presence
Four of Ocean’s six drivers are dedicated to the frequencies above the bass system, allowing 64 Audio to carefully shape the regions most responsible for vocal tone, instrumental texture, presence, and spatial realism.
Two balanced armatures handle the primary midrange, while a separate high-mid BA bridges the transition into the tia treble system. The tuning is intended to keep the midrange rich and present while balancing upper-mid energy carefully enough to preserve clarity without making vocals or instruments sound overly forward.
That balance contributes to Ocean’s dynamically neutral character: detailed enough to function as a reference, but voiced around believable tonal relationships rather than exaggerated resolution.
tia High Driver with a Refined Meta-Material Waveguide
Ocean continues one of 64 Audio’s defining technologies with a dedicated tia high-frequency driver and tubeless single-bore acoustic architecture. By reducing the conventional tubing and damping structures between the driver and the ear, tia is designed to minimize unwanted resonance while allowing high frequencies to arrive with greater openness and immediacy.
For Ocean, 64 Audio further refines the tia waveguide with a recently patented meta-material. This acoustic structure is used as an additive tuning mechanism, shaping the upper frequencies while preserving the natural openness of the tia driver.
The intended result is treble that sounds extended and revealing without becoming forced: high-frequency detail with a lifelike, effortless character that integrates naturally with the rest of the spectrum.
Passive Acoustic Control: 32 Ways to Tune Ocean
Ocean goes considerably further than interchangeable pressure-relief modules alone. Its Passive Acoustic Control system gives the listener three separate mechanical ways to alter the IEM’s acoustic behavior.
Two interchangeable stainless-steel tia screens adjust high-frequency damping. Four back-vent filters change the pneumatic loading of the isobaric dynamic-driver system. Four Apex modules — m20, m15, m12, and mX — alter venting and isolation.
Together, those components provide as many as 32 possible combinations. Instead of offering a simple bass switch or two fixed signatures, Ocean lets listeners experiment with different relationships between low-frequency behavior, treble energy, isolation, pressure relief, and perceived spaciousness.
That makes Ocean unusually adaptable for a flagship IEM. You can settle on a preferred reference configuration and leave it there, or treat the tuning system as part of the experience and adjust Ocean around different music, sources, environments, and personal preferences.
Apex Pressure Relief and Adjustable Isolation
64 Audio’s patented Air Pressure Exchange, or Apex, technology vents pneumatic pressure that would otherwise build inside a sealed ear canal. Reducing that pressure is designed to improve long-term listening comfort while contributing to the spacious presentation for which 64 Audio’s IEMs are known.
Ocean includes all four Apex modules: m20, m15, m12, and mX. Depending on the module installed, rated isolation ranges from approximately -10dB to -20dB.
Because Apex is integrated into Ocean’s broader tuning system, changing modules affects more than isolation alone. It provides another way to alter how physically sealed, spacious, and acoustically loaded the IEM feels.
Wide, Separated, but Still Cohesive
Ocean is designed around a wide soundstage, strong image separation, and full-range clarity. Those qualities are especially important in a six-driver design, where technical separation can become less convincing if the individual frequency bands do not integrate properly.
64 Audio’s objective is to give instruments their own clearly defined positions while maintaining the continuity of a real performance. Bass remains foundational, the midrange carries weight and texture, upper mids provide presence and realism, and the tia treble system adds air and extension without pulling the presentation apart.
For listeners moving into a flagship IEM because they want more resolution and spatial information, Ocean is designed to deliver both without losing the sense that everything belongs to the same recording.
Champagne Copper Aluminum Construction
Ocean is housed in a T6061 aluminum shell finished in Champagne Copper, with a machined faceplate inspired by aeolian ripples — the wave-like geological patterns formed in sediment by moving wind.
The design is deliberately restrained for a modern flagship. Instead of relying on elaborate decorative materials or highly ornate faceplates, 64 Audio uses machining, texture, proportion, and finish to give Ocean its identity. The rippled faceplate provides visual depth while maintaining the clean industrial aesthetic associated with the brand.
Two Shielded UP-OCC Cables Included
Ocean includes dedicated cables for both standard single-ended and balanced systems, so there is no need to choose a termination at purchase or immediately add an aftermarket cable.
Both cables use four-core, cross-braided 24 AWG Litz construction made from silver-plated UP-OCC single-crystal copper, with 99 strands per core and a total specified impedance of just 0.29Ω. The shielding is designed to reduce interference while maintaining transparent signal transmission.
A 3.5mm terminated cable is included for conventional single-ended sources, along with a 4.4mm balanced cable for compatible DAPs, DAC/amps, and desktop headphone systems. Both connect to Ocean through standard 0.78mm 2-pin connectors.
A New Benchmark for 64 Audio
Ocean draws on the technologies 64 Audio has developed since its founding in 2010, but it does not simply package familiar ideas into a more expensive shell. The isobaric dynamic bass system, four-way hybrid architecture, refined tia waveguide, interchangeable vent filters, tuneable tia screens, and complete set of Apex modules make it one of the company’s most ambitious universal designs.
Its appeal is equally technical and practical. In its default configuration, Ocean is intended to function as a dynamically neutral flagship with full-range realism, strong low-frequency authority, rich mids, natural treble, and expansive staging. For listeners who want to experiment, Passive Acoustic Control opens the same platform to dozens of different acoustic configurations.
Ocean is 64 Audio’s flagship for the listener who wants both a finished reference tuning and the freedom to explore what else the same six-driver system can do.
Key Features
  • Flagship universal in-ear monitor from 64 Audio
  • Six-driver, four-way hybrid architecture
  • Dynamically neutral sound signature focused on broadband realism
  • Two custom cone-to-cone isobaric dynamic drivers for low frequencies
  • Two balanced armature midrange drivers
  • Dedicated high-mid balanced armature driver
  • Dedicated tia high-frequency driver
  • Wide soundstage with strong imaging and instrument separation
  • Powerful, controlled, full-range low-frequency response
  • Rich and present midrange
  • Natural upper-midrange tuning focused on realism
  • Refined tia waveguide incorporating 64 Audio’s patented meta-material
  • Patented Tubeless In-Ear Audio (tia) technology
  • Patented Air Pressure Exchange (Apex) pressure-relief technology
  • Passive Acoustic Control system with up to 32 configurations
  • Two interchangeable stainless-steel tia screens for high-frequency damping
  • Four interchangeable rear vent filters for dynamic-driver pneumatic loading
  • Four included Apex modules: m20, m15, m12, and mX
  • Approximately -10dB to -20dB isolation depending on Apex configuration
  • Champagne Copper finish
  • T6061 aluminum shells with machined faceplates
  • Aeolian ripple-inspired faceplate design
  • Standard 0.78mm 2-pin cable connection
  • 3.5mm and balanced 4.4mm shielded cables included
  • Silver-plated UP-OCC single-crystal copper cable conductors
  • 24 AWG four-core Litz cable construction
  • 99 strands per cable core
  • 0.29Ω specified cable impedance
  • Designed, assembled, and quality-controlled in the United States
Technical Specs
Product Type Universal in-ear monitor
Driver Count 6
Crossover 4-way
Low-Frequency Drivers 2 custom cone-to-cone isobaric dynamic drivers
Midrange Drivers 2 balanced armatures
High-Mid Driver 1 balanced armature
High-Frequency Driver 1 tia high driver
Frequency Response 5Hz–22kHz
Impedance 9.5Ω @ 1kHz
Sensitivity 103.7dB/mW @ 1kHz
Isolation Approximately -10dB to -20dB depending on Apex module
Shell Material T6061 aluminum
Faceplate Machined aluminum
Color Champagne Copper
Connector 0.78mm 2-pin
Cable Conductors Silver-plated UP-OCC copper
Cable Construction 24 AWG, 4-core Litz
Strands 99 strands per core
Cable Impedance 0.29Ω total
Included Terminations 3.5mm single-ended and 4.4mm balanced
What's in the Box
  • 64 Audio Ocean Universal In-Ear Monitors
  • Carry case
  • TrueFidelity foam ear tips — Small, Medium, Large
  • SpinFit silicone ear tips — Small, Medium, Large
  • Silicone ear tips — Small, Medium, Large
  • 3.5mm shielded cable
  • 4.4mm balanced shielded cable
  • Apex m20 module
  • Apex m15 module
  • Apex m12 module
  • Apex mX module
  • Shirt clip
  • Cleaning tool
  • Cleaning cloth
  • Round sticker
