YU9 QUE - My Favorite IEM Under $500
A $400 IEM with flagship-inspired tuning, standout treble, and a refined midrange presentation—Precogvision thinks the YU9 Que is an IEM you should know about.
The YU9 Que is a low driver-count, hybrid earphone that hails from China. I heard whispers about it over a year ago from someone in the industry, but I have to confess that I slept on it as life was busy. Fast forward to CanJam SoCal 2025 and another friend, Toranku, encouraged me to give it a chance. I’m sure glad I did. Now, courtesy of Elise Audio, I have a reference unit for which I can share some extended thoughts on.
Sparknotes summary: Buy this IEM if you appreciate flagship-style tuning that’s dialed the creative liberties back a notch. The Que is basically desert island IEM material at $400.
Starting from the bass of the Que, it's good but not great. Its bass presentation is highly reminiscent of the full-BA IEMs from 64 Audio like the U12t. This is realized by a slightly soft attack edge, slightly rougher texture than the 64A IEMs, and a tilt toward mid-bass ‘thump’. The Que still goes surprisingly deep at times, but it’s never to the point of truly rumbling or exhibiting the density of something like the ThieAudio Valhalla. Ultimately, it’s clear that the bass on this set is mostly foundational and about aiding coherency more than it’s concerned with being ‘slammy’ or dominant.
Now, at first glance, the midrange of the Que is different from many modern IEMs. But look closer, and one realizes that it is heavily inspired by the QDC IEMs which also have roots in China. Nearly ten years ago, these IEMs pioneered a tuning that is structured by a linear rise from 1-4kHz yet with relatively tame amplitude. Look even closer, and one will see that the Que *refines* this midrange: the Que’s pinna rise eschews the slight uncanniness of the QDC IEMs (which actually begin rising closer to 600Hz) and smoothens the 2-4kHz region.
In totality, the Que’s midrange is not neutral but is balanced with a slightly warm-coloration across both male and female vocals. I have to emphasize that this is something of a Goldilocks midrange: It’s rare to hear competent midrange tuning under $500, much less unorthodox midrange tuning. Part of the reason many midrange tunings at this price point fail, though, is because of how they tune treble - and this is really the Que’s standout.
The Que’s treble reminds me of the Elysian Annihilator's treble if you dialed it back a couple decibels across the board. It consists of a series of micro-peaks, so in level with each other and small to be heard as smooth in collective. Aided by a recession from 5-6kHz, the result is a treble response that’s potentially bright depending on tip/source pairing, but pretty forgiving when dialed in. Extension is excellent - easily pushing past 15kHz and to the limits of my hearing but not in an exaggerated manner like the Annihilator. It's like the Que's not trying at all in the treble, yet delivering every little sonic minutia that's up there. Importantly, it’s also bringing back the detail that can be lost by the more reserved pinna gain and warmer lower-midrange.
You’ll notice that I compare the Que to a lot of noteworthy IEMs, and the reason for this is simple: I can’t help but feel that the Que feeds on DNA from some of the best flagship IEMs to have graced the industry. Is it better than these IEMs? Most of them, I’d argue no. But simultaneously, then, it’s not hard to see why the Que’s sonic performance belies its $400 price point.
Again, when I first heard the Que, it was at a show where I went in listening blind (I’d literally forgotten about the IEM at this point). At that point in time, I thought the Que sounded like $700-800 for its intangibles - a sentiment I stand by after extended listening.
Simply put, the Que has excellent presentation. It’s like every instrument has a defined, glove-like pocket on the stage despite the Que not necessarily having the largest soundstage. I believe a lot of this is tied to the overall, W-shaped nature of the Que’s tuning wherein individual frequencies have their respective contrast yet, almost paradoxically, there is very little auditory masking. The timbre of the Que is not necessarily ‘correct’ either, but I wouldn’t say it sounds wrong; it has slight texturing throughout both the midrange and treble that sounds quite believable.
To be clear, if only for technical performance, the Que doesn't supersede modern, top kilobuck sets like the ThieAudio Monarch MKIV and Mysticraft Myth even if it puts up a good fight. Let’s compare to other popular $500 sets like the XENNS Top Pro and Tea Pro (SE) then. I believe some listeners might prefer the Top Pro’s ear-grabbing signature. But in longer-term listening, the Que takes the cake for me with a more coherent presentation and a less exaggerated sense of detail. Similarly, versus the Tea Pro SE - which is an excellent set, don’t get me wrong - the Que has just a little more texture in its treble and that last leg of tuning refinement.
The Moondrop Variations is another popular $500 IEM. In fact, it’s been my $500 benchmark for the last four years or so, as I don’t really find the market has put out anything better - possibly until now. The Variations offers a distinctly different flavor of tuning that’s oriented around the Harman target. It’s much forward in its sub-bass and upper-midrange presentation, and it has a conventionally ‘smooth’ treble response without micropeaks. All of this means that, between the Que and Variations, one is not necessarily better than the other even if I would give the edge to the Que for both my preferences and pure sound quality.
Against a true flagship IEM, like the ThieAudio Valhalla, the Que starts showing limitations. These two IEMs actually sound fairly alike to me in terms of tuning and ethos. But comparatively, the Valhalla is decidedly more planted in its bass response, lusher in its midrange presentation, and more spirited in its treble (albeit not necessarily better in this department). The Valhalla also simply has superior technicalities to my ears - it has a more speaker-like presentation to the way it images and it has more dynamism, especially behind bass notes. But the difference isn’t big at all.
The bottom line? It’s like clockwork reading, hearing about IEMs supposedly punching beyond their price point. But experience - and my ears, at least - have rarely found this to be true. The Que is one of the few IEMs that, at this point in time, I would consider to meet the bar. It has tried-and-true flagship roots at the sub-$500 price point, genuine S-tier tuning, something that only several years ago I would have balked at being possible. Again, I will emphasize it does not have flagship IEM performance, or even top kilobuck IEM performance - that bar has also been raised in the last couple years. But there’s no shame in being ‘scarily close’ for a $400 IEM.
