HEDDphone DX review: A better D1?
The HEDDphone DX keeps the D1’s basic identity, but refines the fit, fills in the bass, smooths the treble, and gets much closer to an ideal tuning.
The HEDDphone DX is best understood as a refinement of the HEDDphone D1 rather than a fresh start, and in my view that is mostly very good news.
It keeps the broad identity that made the earlier model appealing, namely a technical, neutral, trustworthy sort of presentation that stays close to "tilted Diffuse Field behavior," but it also addresses several of the places where I found the D1 frustrating to live with day to day.
The result is a headphone that sounds better immediately, asks less of EQ, and feels more polished physically, even if one lingering tuning issue still stops it short of being an outright slam-dunk recommendation.
What we like
- More out-of-box bass
- Tamed 5.5 to 6 kHz treble
- Suspension strap and lighter clamp
- Easier EQ to ideal
What we don’t like
- 3 kHz ear-gain peak
- Still needs one EQ band
Build and comfort
Physically, the DX is extremely similar to the D1. The cups, yokes, and parts of the headband appear to use the same chassis elements, while the finish moves to a soft-touch matte treatment that gives it a more premium look and feel. The grilles also look more transparent, with bolder white accents that make the design more visually interesting without losing the understated, professional-tool character that I think suits this headphone well.
The pads do not seem meaningfully changed to me, at least not in any way I could clearly see or feel. The bigger improvement is the headband. The old foam padding is gone, replaced by a soft fabric suspension strap, and while I did not personally struggle with the original headband, this is still the better solution. It is slightly more comfortable, it should work better across a wider range of head shapes, and it also reduces clamp out of the box.
That clamp change matters. The DX feels a bit less aggressive straight away than the D1, and because the top no longer has the same plastic reinforcement, it should also be easier to adjust if you want even less pressure. Add in the generous swivel that remains from the previous design, and I think HEDD made smart choices here: keep what already worked, improve the points people complained about, and do it without disrupting the fit basics.
Sound changes
So how does it perform? Sonically, this is where the extra cost begins to make sense, because I found the DX to be a straight-up better sounding headphone than the D1.
The biggest fix is bass. My main complaint with the D1 was that it rolled off too much under roughly 100 Hz, which left it sounding lean without EQ. The DX changes that immediately. Out of the box, it now has a substantial amount of bass, enough that I no longer feel it is lacking there at all. If I were fine-tuning purely for my own preferences, I might pull down a little mid-bass around 150 Hz, but that is firmly in the realm of preference optimization rather than problem-solving.
Elsewhere, the overall shape remains recognizably related to the D1, but there are a few subtle shifts that matter quite a lot in practice. There is now a mild dip around 1 to 2 kHz, which I personally like because it helps things sound a little larger and more spacious. More importantly, the focus of the midrange bump has shifted from around 1.5 kHz toward 1 kHz. For me, that change helps avoid some of the honky, shouty character the D1 could produce, while also making the sound more lively in a way that feels deliberate rather than exaggerated.
The treble is also better behaved. The 6 kHz region has been tamed, and on my own head that matters more than the generic measurement alone might suggest. With the D1, I got a fairly substantial peak at around 5.5 kHz, and it was something I really did need to EQ down because it could turn sibilant and harsh. On the DX, that issue is still present to some degree, but it is clearly reduced, enough that I no longer feel any need to fix it for ordinary listening.
Put together, these changes move the DX closer to a diffuse-field style response with fewer obvious mistakes. Subjectively, it just sounds more correct to me, and that is not only about tonal balance in the abstract. I heard an upgrade in spaciousness, and somewhat unusually, an upgrade in timbre at the same time.
Out of the box and with EQ
This is really where the DX separates itself from the D1. With the older model, I felt like EQ was necessary for comfortable long-term listening. I had to add bass, tweak the mids, deal with the treble peak, adjust the ear-gain region, and ideally tilt the whole thing a little as well. None of those were giant changes individually, but together they meant the stock tuning was never quite settled for me.
The DX is different. Out of the box, I think it is great. It is punchier, more spacious, and less peaky through the treble. Most of the major issues I had with the D1 are fixed, and even if you are somebody who likes to EQ everything anyway, the DX is simply easier to get to an ideal result.
For me, the EQ story is now refreshingly simple: pull down the 3 kHz region by a couple of dB, and that is the only change I feel I truly have to make. Everything beyond that is optional seasoning. That is a huge improvement over the D1, because the difference between “needs tuning work” and “benefits from one small preference correction” is not subtle in day-to-day use.
The remaining issue
There is, however, one holdout, and it is the reason I am not fully unreserved about this headphone.
The ear-gain peak around 3 kHz is still too high for me, essentially the same core issue I had with the D1. On the DX it is less intrusive because the improved bass balance makes the rest of the response feel more grounded, so I no longer consider it a mandatory fix in the same way. Even so, I do prefer the DX once that area is trimmed down slightly, and I really wish HEDD had gone the last step and addressed it at the source.
That is the frustration: so many of the prior problems have been solved, and the one that remains is exactly the one most likely to keep some listeners from hearing this as fully relaxed and natural out of the box. It does not ruin the headphone, not even close, but it does keep it from being the easy standout recommendation it otherwise could have been.
Against the competition
At this price, the DX is not alone, and its strengths make more sense when set against the alternatives I would personally be looking at.
Against the Hifiman Arya Unveiled, I hear a trade-off rather than a clean victory. I prefer the Arya Unveiled's midrange presentation, particularly because I like a slightly lower 2 kHz region and a more gradual downward slope from bass into mids. At the same time, each headphone has one main treble-region issue I would want to fix: 3 kHz on the DX, 5 kHz on the Arya Unveiled. With those corrected, I would struggle to pick a firm favorite. The Arya Unveiled would likely get my nod for classical and more acoustic material, while the DX would pull ahead for livelier, more percussion-heavy music where I want more bass kick. The DX is also the safer all-rounder for general listening, because its lower upper-treble energy makes it less likely to turn already bright recordings painful.
Against the Aune AR9000, the calculus shifts. The AR9000 has better bass in my view, with a sub-bass-focused shape and a gradual slope into the mids that I still think is exceptional. It is also easier for me to listen to through the midrange and lower treble out of the box, not necessarily because it is better tuned everywhere, but because too little ear gain tends to be less problematic than too much. That said, I would give the DX the edge in upper treble. It sounds smoother, more evenly filled in, and more informative there, whereas the AR9000 is rockier and harder to correct if you do want to tune it further.
The cheaper AR3000 is a useful reminder that price does not cleanly predict performance. Bass between it and the DX is nearly identical to my ear, though the DX comes across as a bit more incisive because its treble better defines the leading edge of things like kick drums. The AR3000 places 2 to 3 kHz closer to where I would personally want it, but its drop around 4 to 5 kHz makes it more relaxed and laid-back, which also means less technically impressive sounding. The DX is better, yes, but not by a dramatic margin, and the real advantage is that it is easier to EQ because the changes I want are broader and simpler.
Verdict
I really like the HEDDphone DX. It is comfortable, fun, engaging, and technically capable, without getting there by being wildly colored, and it remains close enough to a reference style of balance that I can also see the appeal in production use.
More importantly, it is a meaningful upgrade over the D1. The low end is fixed, the treble is more controlled, the midrange adjustments improve both spaciousness and timbre for me, and the physical design is more accommodating. If you never plan to use EQ, this is clearly the better buy of the two. If you do use EQ, it is still the better buy, because getting it to an ideal response is dramatically simpler.
The only reason I stop short of full-throated praise is that 3 kHz region. If HEDD had pulled that down slightly, I think this would have been one of the easiest recommendations in its class. As it stands, I still think they have made a genuinely better headphone, just one that, for most people, will likely become truly excellent with one small EQ cut.
