Our Headphone Review Gear & Review Process
Resolve, GoldenSound, and Listener break down the exact gear, setups, and processes they each use when reviewing headphones, DACs, and amps. From reference headphones and level-matching methods to EQ tools, measurement rigs, and music choices, they compare how their review chains differ. and why each approach works for them.
Here’s a quick breakdown of what each reviewer—Resolve, GoldenSound and Listener—uses for headphone and source evaluation, and the reasoning behind each setup.
Resolve
Core Chain
  • DAC: Matrix X-Sabre Pro
  • Amp: Violectric HPA V550
  • Tube Amp: ampsandsound Kenzie (for output-impedance testing)
  • Measurement Rigs: B&K 5128, GRAS 43AG (KB5000 pinna + RA0402 coupler)
Headphone References
  • Neutral Reference: HEDD Audio D1
  • Gaming Headset Reference: Audeze Maxwell
  • ANC Reference: Sennheiser HDB 630
Method Notes
  • Chooses gear with high power and low output impedance to drive a wide range of products.
  • Uses tube amp or impedance adapters to test how headphones behave with higher source impedance.
  • Measures after listening to confirm consistency and spot fit/positioning issues.
GoldenSound
Core Chain
  • DAC: Ferrum WANDLA GoldenSound Edition
  • EQ/Utility: Zähl EQ1
  • Amp: Zähl HM1
  • Measurement Tools: Audio Precision APX555 + Neurochrome dummy load
  • Software: Roon (multi-endpoint source)
  • Hifiman Susvara (sometimes—but not always—EQ’d with a bass shelf)
Method Notes for testing DACs
  • HM1 allows instant A/B testing between DACs with built-in volume matching.
  • Uses Roon for synchronized playback across multiple DACs and systems.
  • Listens before measuring for source gear to avoid bias from small measurable differences.
  • Uses speakers as a secondary reference point for source evaluation.
Listener
Core Chain
  • Reference Headphone: Sennheiser HD 800 (with personalized and extremely neutral EQ preset)
  • Reference IEM: Truthear PURE
  • Source: MacBook Pro M3 Max + multiple dongles
  • Comparison Setup: Multiple dongles, routed via Audio Hijack (Rogue Amoeba) for individual volume setting based on appropriate level for each headphone to be matched.
Method Notes
  • Anchors evaluations to a personally tuned HD 800 that serves as a neutral baseline.
  • Prioritizes transducer behavior over DAC/amps because the latter barely (if ever) makes a difference.
  • Uses Audio Hijack to split signals and level-match multiple headphones for comparison.
  • Resolve focuses on broad drive capability and subjective listening with measurement cross-checks.
  • GoldenSound emphasizes transparent DAC switching and precise A/B testing.
  • Listener centers around a single neutral reference and controlled comparisons.
We all do things differently—different chains, different biases—but the goal’s the same: reliable, repeatable impressions that help people find the gear that makes their music sound its best.
