DCA Core First Impressions - Headphone tuning the 'right' way?
The $900 DCA Aeon CORE fixes past errors with tuning to the Harman target, delivering a highly forgiving, timbrally natural alternative to the flagship E3.
If you’ve been following Dan Clark Audio, you know many of their closed-back headphones have historically aimed squarely at the Harman target. However, the Harman target was originally developed on an older ear simulator and a custom Welti-modified pinna that differs significantly from the modern GRAS industry-standard equipment reviewers use today.
When manufacturers measure headphones on modern gear like the GRAS KB5000 ear and map them against that older target curve, an inherent incompatibility arises. This being common practice has meant audiophiles think they know what the Harman target sounds like on a modern graph, but in reality, nobody has truly heard the actual target from the original research.
DCA had been alerted to this disconnect, prompting them to look backward. With help from Sean Olive, they utilized a custom Welti-modified pinna based on the original 2018 research to directly influence the tuning target for this new platform, the Aeon Core.
While the industry desperately needs to move past the rigid paradigm of tuning strictly to a single target line, using a Welti pinna retrofit to inform design decisions is a commendable move. It fixes an underlying translation issue, and the results were—if Aeon CORE is any indication—probably worth the effort.
The Sound: A Forgiving Counterpart to the E3
Subjectively, the Aeon CORE functions beautifully as a less contrasty, more relaxed alternative to DCA’s flagship E3. While the E3 focuses heavily on contrast with intense bass and low-treble energy, the Aeon CORE leans into a more timbrally appropriate, highly versatile presentation.
It is an immediate step up in sound quality from the closer-priced (but still more expensive) Noire X Closed, which had an exaggerated 2 to 3 kHz presence that made instruments incisive at the cost of making vocals shouty, glarey, and ultimately fatiguing. By comparison, the new CORE dials back the ear gain and smooths out the treble.
That is not to say it sounds completely flat to my ear on first listen. During my initial time with it, I did notice a slight forwardness around 2.5 kHz and another mild bump at 5 kHz, as well as a dip around 7 kHz.
However, the aggregate tuning yields a forgiving signature that handles a much wider range of music than something like the Audeze LCD-X Closed. It has the kind of transparent presentation where you can completely forget you are wearing a headphone and can just lock into the music—something we have desperately wanted in a closed-back headphone for a very long time.
Final Thoughts
Dan Clark Audio has delivered a solid new entry with CORE. It stands out as one of our favorite headphones DCA has ever produced, serving as a more accommodating/versatile foil to the E3, while (in our opinion) besting the older Noire X Closed.
More importantly, its unique development effort yielded a headphone that is actually hitting the target as it was truly intended. We haven't had the chance to get this unit on our own measurement system yet, but we are fascinated to run a full analysis. Once our review sample lands in the lab, we will provide a comprehensive breakdown, so make sure to stay tuned.
