Top 3 USB Headphone Amp/DACs under $200 in 2019
A good DAC is the easiest way to upgrade your headphone experience (assuming you already have good headphones and a good source). Unfortunately, there are many people who will never experience the sound improvement of a DAC because they don’t know what to buy. We’d like to help with that.
To learn more about DACs, here's a good place to start: What is a DAC? or our post on using DACs and AMPs with computers.
Here are 3 incredible DACs under $200 that will make a huge difference in your listening experience.
The Best USB Amp/DACs Under $200:
1. AudioQuest DragonFly USB DAC/Headphone Amplifier
Good for: Super portable, crazy performance, MQA, harder to drive headphones
Audioquest is best known for their premium cables that can run into $1000s per meter. They have taken their expertise to the world of DACs and developed what we think is the ultimate sub $200 audio upgrade. You will be able to hear the difference the DragonFly makes instantly.
It’s just a bit larger than a USB stick and the DragonFly Red brings huge performance for its size. It works with any Mac or PC computer and also works with Android and iOS phones (you have to buy a dongle for both).
SPECS
- Plays all music files: MP3 to high-res
- Compatible with Apple and Windows PCs, as well as iOS and Android mobile devices (requires Apple Camera Adapter or Made for Android/OTG adaptor)
- Drives headphones directly
- Fixed output feeds preamp or AV receiver
- Asynchronous transfer ensures digital timing integrity
- High output (2.1 volts) drives almost all headphones, including power-hungry models
- 32-bit ESS 9016 DAC with minimum-phase filter
- Bit-perfect digital volume control
2. AudioQuest DragonFly Black USB DAC/Headphone Amplifier
Good for: Portability, cost to performance ratio
The DragonFly Black is a more cost-effective DAC/AMP from Audioquest that still provides a huge performance boost. It’s half the price of the Dragonfly Red, but in our opinion, it gives 80% of the performance.
SPECS
- Medium output (1.2 volts) drives a wide range of headphones
- 32-bit ESS 9010 DAC with minimum-phase filter
- Analog volume control
3. iFi Audio Nano iDSD Black Label
Good for: Functionality to cost ratio
British-based iFi has been making a huge splash in the DAC/Amp market. This DAC is up to date with the latest technology and for the price packs a ton of functionality.
The Nano is not as portable as the DragonFly’s and the form factor looks a little old-school compared to the competition. However, it’s the features that get us excited.
It handles MQA natively, decodes PCM up to 32BIt/384kHz and comes with a lot in the box:
- IFI Nano iDSD Black Label
- Male-to-female USB charging/data cable
- USB-A-to-USB-B adapter
- USB-A-to-USB-B adapter cable
- 2x Silicon bands
- Soft storage pouch
- Instruction leaflet(s)
SPECS
- 32-bit 384 kHz
- Works with iOS, Android, OSX and Windows
- 10 hours of battery life
- Hi-Res Audio Certified
- DSD, DXD, PCM DAC by Burr Brown Bit-Perfect DSD processing, BitPerfect DXD processing
- Low-jitter crystal clock
- Audio Formats
- DSD 256/128/64/12.4/11.2/6.2/5.6/3.1/2.8
- DXD 384/352.8kHz
- PCM 384/352.8/192/176.4/96/88.2/48/44.1kHz
- MQA 88.2/96/176.4/192kHz filters
Those are our favorite USB DACs under $200. They combine portability, price and performance into a package that is very accessible. If you want to upgrade your computer or cellphone listening experience without dropping a ton of cash, one of these USB DACs is a no-brainer.
If you have any questions about the right DAC for you, fire us an email at info@headphones.com
