Woo Audio WA7 Fireflies 3rd Gen Headphone Tube Amplifier
Amplifier type
Vacuum tube
Portability
365-day returns
Woo Audio
From the Woo Audio Team
Nearly a decade ago, we set out to create an attractive, high-performance vacuum tube amplifier that will delight the eyes and ears of music lovers. The original WA7 fireflies headphone amplifier/DAC was born. We are proud to introduce to you the improved 3rd generation of our award-winning WA7 fireflies.
Keeping the same elegant look that makes WA7 fireflies unique, the new 3rd gen now features a built-in linear power supply making the setup a breeze and a one-box solution. In addition, the 3rd gen employs a balanced headphone output driven by a pair of 12AU7 vacuum tubes. The power output is over 1.5w of power per channel @4 Ohms; ideal for a wide range of IEM (in-ear monitors) and power demanding full-sized headphones. The user-replaceable vacuum tubes can be upgraded at any time to customize the sound to the listener's preference. The class-leading performance ESS SABRE DAC allows the user to enjoy music from streaming services such as TIDAL, Qobuz, Apple Music, and Amazon Music HD in lossless resolution.
You asked for it and we listened. The new 3rd gen is also a tube preamplifier enabling the user to integrate WA7 fireflies with their home speakers system or drive a pair of desktop-powered speakers for more ways to enjoy the uncompromised sound. See the quick start guide for all the possibilities of this amazing little cube.
Highlights
Updated to 3rd generation in Sept 2021
Compatible with Apple iPhone/iPad, Android devices, Mac and Windows computers
Class-A balanced headphone amplifier and DAC
Up to 1.5w power output (4.4mm balanced)
Tubes: 12AU7 / 5963 driver tubes, self-biasing
Premium Polytetrafluoroethylene (PTFE) tube sockets
ESS SABRE Audiophile DAC up to 24-bit/384kHz PCM, and 128DSD/5.6MHz
XMOS xCORE-AUDIO asynchronous USB compatible with PC, Mac, Android and iOS devices (with Apple CCK or Android OTG adapter)
High-retention USB connector x 1
RCA analog Input x 1
4.4mm (5-pole) by Pentaconn by NIPPON DICS balanced headphone output (recommended)
6.3mm (1/4”) stereo headphone output
Compatible with full-size headphones and IEMs (8–600 Ohms)
Frequency response: 10Hz to 46kHz, -3dB
Signal to noise ratio: 100 dB
Tube preamplifier function (PRE-OUT):
- 4.4mm (5-pole) by Pentaconn by NIPPON DICS balanced pre-out output (recommended)
- 6.3mm (1/4”) stereo pre-out
Anodized aluminum chassis, available in midnight black or silver [coming soon]
External dimensions with glass: 5.25" (H) x 4.8" (W) x 6" (D)
Weight: 8.5 lbs.(3.9kg)
Internal linear power supply
Global voltage (100v–240v) without converter
Designed and assembled in New York, USA
Three-year limited warranty
IMPORTANT NOTICE: cannot convert unbalanced to balanced, do not use headphones adapter to convert 6.3 / 3.5mm --> 4.4mm.
