Woo Audio
Woo Audio WA6 Desktop Tube Headphone Amplifier
Amplifier type
Vacuum tube
Portability
Handcrafted since 2008, WA6 (2nd gen) has set the standard for headphone amplifiers in its class. It can drive full-size headphones and in-ear monitors ranging from 8–600 Ohms with ease. WA6 (2nd gen) is an all-tube design, Class-A, transformer-coupled, single-ended triode (SET) amplifier. Under the hood of the all aluminum chassis is the same clean point-to-point wiring and premium quality parts found in our top tier models. WA6 (2nd gen) is an exceptional headphone amplifier for every music lover.
*AC power cord and audio cables are not included
Highlights
- 2nd gen is a minor update to driver/power tubes from 6v to 13v
- Tubes: 13DE7 driver/power x 2, 5U4G rectifier x 1
- Polytetrafluoroethylene (PTFE) tube sockets
- Singled-ended Triode, Class-A
- Transformer-coupled, Point-to-Point wiring
- Pseudo-dual power supply
- RCA input x 1
- HI / LO headphone impedance switch
- 1/4" (6.3mm) stereo headphone output (8–600 Ohms)
- ALPS potentiometer and power switch
- Anodized aluminum chassis, available in black or silver
- Self-biasing with compatible tubes
- Global voltage (100v–220v) without converter
- Dimensions: 6"(H), 5½"(W), 13"(D), 13 lbs.
- Designed and assembled in New York, USA
- Three-year limited warranty
In The Box
- Woo Audio WA6 (2nd gen) headphone amplifier x 1
- 13DE7 vacuum tube x 2
- 5U4G vacuum tube x 1
- Quick start guide
