Topping
Topping D90 III Sabre Desktop DAC
Regular price $764
Sale price $764 Regular price $899.00
1 of 7
Topping
Regular price $764
The Next Level of Sound
The Topping D90 III Sabre Desktop DAC returns, setting a new benchmark in the realm of audio fidelity. Engineered with dual ES9039SPRO DAC chips and boasting an impressive 135dB SNR and <0.000045% THD+N, this fully-balanced decoder is designed to deliver a listening experience that’s as close to perfection as it gets.
Dual ES9039SPRO Chips: Precision Engineered for Peak Performance
At the core of the D90 III, two ES9039SPRO chips work in harmony to provide an unparalleled audio experience. This dual-chip setup ensures that each audio channel operates independently, leading to an enhanced Signal-to-Noise Ratio, a wider dynamic range, and a marked reduction in distortion, setting a new standard for sound quality.
Cutting-edge CPLD Processing: Jitter-free, Pristine Audio
Incorporating a Complex Programmable Logic Device (CPLD), the D90 III stands out for its extraordinary jitter rejection capabilities. This advanced processing refines the clock signal to an extraordinary degree, offering jitter levels as low as -160dB across various inputs and ensuring that your music is delivered with absolute clarity and precision.
Innovations in I/V Conversion: Pushing the Boundaries of Audio Reproduction
The D90 III features a state-of-the-art I/V conversion circuit, a testament to Topping's commitment to audio innovation. This new circuit design significantly reduces distortion and noise while minimizing its spatial footprint, thereby enhancing the overall performance of the DAC chip.
High-Resolution Wireless Audio with Bluetooth 5.1
The inclusion of a QCC5125 Bluetooth 5.1 chip elevates your wireless audio experience. Supporting high-resolution codecs such as LDAC and aptX-Adaptive, the D90 III allows for the wireless transmission of high-quality audio up to 96kHz/24bit, redefining your expectations of wireless sound.
Universal Compatibility and Unparalleled Ease of Use
The D90 III is remarkably user-friendly, offering broad compatibility with various operating systems including Windows, Mac, Linux, and iOS/Android. For Windows users, ASIO support is just a simple driver setup away. The device’s USB hardware, based on XMOS XU316 and Thesycon drivers, ensures a stable and reliable connection.
Versatile Output Modes for Every Audiophile's Need
Tailor your sound with the D90 III's versatile output modes. Choose between the balanced XLR output and single-ended RCA output to best suit your audio setup. With XLR 4V and RCA 2V outputs for a wide range of devices, and XLR 5V and RCA 2.5V for enhanced performance, the D90 III offers flexibility without compromising on sound quality.
A Symphony of Advanced Features
The Topping D90 III Sabre Desktop DAC is not just an audio device; it's a masterpiece of sound engineering. With dual ES9039SPRO chips, advanced CPLD processing, and an innovative I/V conversion circuit, the D90 III delivers an audio experience that's both authentic and breathtakingly clear. The addition of high-resolution Bluetooth 5.1, universal compatibility, and versatile output modes solidifies the D90 III's position as a leading choice for audiophiles seeking the ultimate in sound quality and convenience.
Specification RCA XLR
THD+N THD+N @ A-wt <0.00006% @1kHz <0.000045% @1kHz
THD @ No-wt 90kBw <0.0003% @20-20kHz <0.0001% @20-20kHz
SNR @ A-wt 129dB @1kHz 135dB @1kHz
Dynamic Range @ A-wt 129dB @1kHz 135dB @1kHz
Frequency Response 20Hz-20kHz (‡0.1dB)
20Hz-40kHz (‡0.3dB)
20Hz-20kHz (‡0.1dB)
20Hz-40kHz (‡0.3dB)
Output Level 2.1 Vrms @0dBFS (4V Mode)
2.6Vrms @0dBFS (5V Mode)
4.2Vrms @0dBFS (4V Mode)
5.2Vrms @0dBFS (5V Mode)
Noise @ A-wt <1.1uVrms <1.1uVrms
Channel Crosstalk -133dB @1kHz -149dB @1kHz
Channel Balance 0.3 dB 0.3 dB
Output Impedance 50Ω 100Ω
