Topping
Topping D50 III DAC
Regular price $229
Sale price $229 Regular price $229.00
1 of 6
Topping
Topping D50 III DAC
Topping D50 III DAC
Regular price $229
Elevating the Standard: The Third Generation D50 III
Discover the pinnacle of digital-to-analog conversion with the TOPPING D50 III Desktop DAC, the latest evolution in the D50 series, now available at Headphones.com. This new generation boasts dual ES9039Q2M D/A chips that deliver exceptional clarity and depth, supporting an impressive array of formats up to DSD 512 and PCM 768kHz. With hi-res certification for audiophile-grade sound, the D50 III exemplifies the continuous innovation and excellence of the illustrious D50 series.
Dual-Core Audio Excellence
At the heart of the Topping D50 III are dual ES9039Q2M D/A chips, each dedicated to a stereo channel. This configuration achieves higher signal-to-noise ratio (SNR), greater dynamic range, and lower distortion, ensuring that every note is rendered with crystal-clear precision. The result is an audio performance that captures the full depth and detail of your favorite music.
Superior Circuit Design
The D50 III features a newly designed I/V conversion circuit that pushes the boundaries of audio reproduction. This innovative circuitry delivers lower distortion, reduced noise, and a compact design, ensuring that the sound remains as true to the original recording as possible. This design philosophy enhances the listening experience, making every session an auditory delight.
Elegant and Robust Construction
Engineered for both function and style, the D50 III's CNC unibody construction is a marvel of precision machining. Crafted from a single piece of aluminum, this design provides superior electromagnetic shielding while adding a touch of elegance to your audio setup. The robust build ensures durability and longevity, making it a reliable component in any audio system.
Wireless Audio Freedom
Experience high-quality audio without the constraints of cables with the D50 III's support for LDAC and other high-definition Bluetooth codecs. This advanced wireless capability ensures that your music retains its high fidelity, even when streamed wirelessly, offering you the freedom to enjoy superior sound quality anywhere in your home.
Seamless Compatibility
The Topping D50 III features dual Type-C interfaces and is compatible with a wide range of operating systems, including Windows, macOS, Linux, and mobile platforms. This universal compatibility ensures a seamless plug-and-play experience, allowing you to easily integrate the D50 III into your existing audio setup and breathe new life into your digital music library.
Versatile Output Options
With both RCA and TRS balanced outputs, the D50 III caters to a variety of professional and personal audio setups. Whether you are connecting to studio monitors, amplifiers, or other audio equipment, the D50 III provides the flexibility you need for a versatile and high-quality audio experience.
Precision Audio Control
Transform your desktop speaker setup with the D50 III's preamp mode, which allows you to adjust volume directly on the device for a streamlined audio experience with active speakers or power amplifiers. Additionally, the D50 III offers a ten-band PEQ adjustment with customizable profiles, enabling intricate tuning for a truly personalized audio experience.
Specification Details
DAC Chips Dual ESS ES9039Q2M
THD+N @1kHz (A-wt) <0.00008% (RCA), <0.00006% (XLR)
THD @ 20-20kHz (90kBW) <0.0004% (RCA), <0.0002% (XLR)
SNR @ Max out 1kHz (A-wt) 127dB (RCA), 132dB (XLR)
Dynamic Range @1kHz (A-wt) 127dB (RCA), 132dB (XLR)
Frequency Response 20Hz - 20kHz (±0.1dB), 20Hz - 40kHz (±0.3dB)
Output Level 2.0Vrms @0dBFS (4V Mode), 2.5Vrms @0dBFS (5V Mode) (RCA); 4.0Vrms @0dBFS (4V Mode), 5.0Vrms @0dBFS (5V Mode) (XLR)
Noise (A-wt) <1.1uVrms (RCA), <1.3uVrms (XLR)
Channel Crosstalk -136dB (RCA), -147dB (XLR)
Channel Balance 0.3dB
Output Impedance 50Ω (RCA), 100Ω (XLR)
What’s Included
  • D50 III Unit
  • D50 III Remote Control
  • USB A-C Cable and USB C-C Cable
  • Bluetooth Antenna
  • Product Information Card
  • Guide for Bluetooth Remote
Experience the ultimate in digital-to-analog conversion with the Topping D50 III, available now at Headphones.com. Elevate your audio setup and enjoy unparalleled clarity, precision, and flexibility with this state-of-the-art DAC. Whether for professional use or personal enjoyment, the D50 III is the perfect addition to any audiophile's collection.
