Thieaudio
Thieaudio Wraith Headphones - Clearance
Regular price $299
Sale price $299 Regular price $549.00
Save 46%
1 of 6
Thieaudio
On saleClearance
Regular price $299
Save 46%
Precision Planar Magnetic Headphones
The Thieaudio Wraith is the next generation of the Phantom, a headphone that gained a loyal following for its modding potential and value. Wraith builds on that foundation with an entirely new 97 mm planar magnetic driver, a redesigned airflow structure, and a complete overhaul of the chassis for long term comfort and durability. The result is a headphone built for both professional audio work and serious music listening.
New 97 mm planar magnetic driver
Wraith uses a new planar driver built around a German conductor membrane, thinner magnetic plates, and a magnetic field that is roughly one and a half times stronger than the previous Phantom. The diaphragm is compressed thinner for more uniform surface tension, which improves responsiveness and resolution across the entire frequency range. Each pair is hand assembled and matched so performance stays consistent left to right. The result is speed, control, and detail that meet the demands of engineers and enthusiasts who want accuracy without losing musicality.
Balanced tuning with natural mids
Thieaudio developed a new tuning for Wraith based on measurements from hundreds of reference headphones. The mids and treble follow a pinna compensation profile that lines up with how the ear naturally perceives sound between one and three kilohertz. This delivers a clear, natural presentation of vocals and instruments with none of the hollow or sharp qualities that can appear in poorly tuned planar designs. Treble remains clean and extends past 40 kHz while the fast planar diaphragm provides tight, accurate bass hits without masking detail in the mids. There is a small amount of warmth for musical enjoyment, while still holding the neutrality needed for studio use.
Precision built for long sessions
The redesigned headband uses a stainless steel frame, CNC machined parts, and soft microfiber padding. A double band system spreads weight evenly to reduce pressure points during longer sessions. The microfiber flannel pads are breathable and isolating, and can be replaced easily. Wraith also uses a detachable cable system so you can replace or upgrade cables without changing the headphones themselves.
Key features
  • New 97 mm planar magnetic driver with stronger magnetic field
  • Improved airflow structure for greater efficiency
  • Balanced tuning with natural mids and extended treble
  • Fast, controlled bass with clean transients
  • Stainless steel and microfiber headband assembly
  • Replaceable microfiber flannel ear pads
  • Detachable OFC coaxial cable with 4.4 mm balanced plug
Specification Details
Type Over ear, open back
Driver 97 mm planar magnetic (98 x 76 mm diaphragm)
Impedance 23 ohms
Sensitivity 101 dB SPL per mW
Frequency Response 20 Hz to 40 kHz
THD Less than 0.8 percent
Cable 1.25 m OFC coaxial shielded cable with 2.5 mm connectors and 4.4 mm balanced plug
What is in the box
  • Thieaudio Wraith headphones
  • Microfiber flannel ear pads (pre installed)
  • 1.25 m OFC coaxial cable with 4.4 mm balanced plug
  • Documentation
