Thieaudio
Thieaudio Elixir In-Ear Headphones - Open Box
Regular price $149
Sale price $149 Regular price $209.00
1 of 5
Thieaudio
Regular price $149
A MATURE SOUND
The Elixir project aims to achieve one principal goal - capture the spirit and emotion of the sound while maintaining a natural tonality that stays true to the recording. The latest driver innovations and acoustic engineering strategies have made possible incredible audio resolution that resonates with an analog texture unique only to the playback from the Elixir. Intended more for luxurious listening sessions rather than stage performances, the Elixir is the audiophile’s dream of a personal vintage sound system.
3-DIMENSIONAL VELOCITY TRANSDUCER
The soul of the Elixir lies within its newly developed 3-Dimensional Velocity Transducer. A completely innovative driver unique from traditional dynamic drivers, the 3D Velocity Transducer diaphragm is composed of beryllium-coated interweaving layers of multi-walled carbon nanotube sheets, which creates an extremely dense and rigid membrane capable of higher tensions and resulting in more responsiveness.
The internal structure of the driver is also novel, utilizing stronger pole magnets and a completely copper voice coil actuator, unlike traditional aluminum ones used in most dynamic driver assemblies.
These features create an extremely enhanced level of audio resolution that transparently reveal the detailed nuances within each note. Moreover, these uncompromising driver components relay a texture within the sound that is completely unique in typical in-ear headphones, which can only be described as vintage and analog.
BALANCED AND NATURAL TONALITY
The Elixir has been meticulously tuned to deliver a natural and balanced sound that is free of any harsh abnormalities or lacking at any frequency interval. This meant the treble had to be detailed and resolving, without introducing any resemblance of piercing or shrill metallic timbre. Following the now well-established natural decay curvature found in all of THIEAUDIO’s signature series in-ear monitors, the Elixir’s upper frequencies deliver a smooth yet precise relay of every miniscule detail in the music.
Oftentimes in in-ear headphones, the sense of audio resolution is simply a derivative of treble resonance. With the 3D Velocity Transducer utilized in the Elixir, realistic high-definition audio is a textural quality found at every frequency range. The bass and midrange had to be tuned in a manner that highlights this feature. Rather than a hard “V”-shaped tuning profile used in most in-ear devices, the Elixir’s mids have been carefully adjusted to be balanced and neutral, with the slightest touch of warmth that elevates the sense of a vintage and lush sound.
The extremely rigid structure of this new diaphragm achieves incredible punctuality in the sub-bass. The bass has been focused to powerfully kick in when required, but not disturb the natural tonality of the overall sound signature, especially when the music doesn’t call for it. This means that you’ll get all of the impactful thump in your hip-hop and EDM tracks, while still being able to enjoy your soft acoustic and classical pieces without any muddying in the sound.
HANDCRAFTED CARE, QUALITY THAT LASTS
Each Elixir unit is handcrafted from precision printed and CNC components. The acoustic chamber housing the 3D Velocity Transducer was carefully engineered to produce the required tonal signature, and each driver unit is manually tested and pair-matched before being hand-assembled. The beautiful anodized aluminum bezel ensures the color won't chip or fade off even with time.
The faceplate is milled from a limited quantity of solid genuine burl wood block, which is coated before being embedded within the aluminum bezel. The final assembly undergoes a round of manual quality assurance inspection, consisting of both acoustic measurements as well as physical hardware inspections, before being packaged.
26AWG HIGH QUALITY LITZ CABLE
The Elixir comes with a high quality 2 core of 92 wires 0.06mm Single-Crystal Copper and 24 wires 0.06mm Silver-Plated OCC Copper Litz upgrade cable. This stock cable has a 3.5mm single-ended cable termination. Additionally, having the 0.78mm 2-pin connectors means that the cable can be detached and changed to fit your needs. Hand paired specifically for the Elixir, the stock cable perfectly complements the aesthetic and sonic pleasures of the IEM.
