Symphonium Audio
Symphonium Audio Triton In-Ear Headphones
Cup style
Wearing style
Driver type
With the Symphonium Audio Triton, Symponium Audio set out to create a sound that is more musical and effortless to listen to. As a first for Symphonium Audio, Triton features a dynamic driver tuned with a 3D-Printed chamber that allows them to provide the punch and body needed for accurate bass reproduction. Its Midrange is tuned to be lush, with the speed and accuracy of a balanced armature. Triton’s treble is also clear, detailed and features the treble extension that Symphonium Audio have come to be known for.
Driven by both dynamic and balanced armature drivers, the Triton will be able to provide endless hours of non-fatiguing listening pleasure.
Tuned in collaboration with Subtonic.
Infinite Linearity
- Featuring Filtered Linear Attenuation Tuning (FLAT) Technology, a propriety circuit developed in-house with Subtonic, Triton will not be affected by impedence mismatch due to difference in source used. You will be able to listen to the same unimpeded sound regardless of the device you are using.
Custom Cable
- A great earphone deserves a cable of equal quality. As such, each Triton comes with a low impedance hand-built 26 AWG Silver Plated OCC Copper cable from Altalune Audio that has been carefully designed - down to the solder used - to provide the best listening experience possible.
Durability
- All Symphonium Audio In-Ear Monitors are made of machined AL6061 Aluminium alloy. The T6 Variant of AL6061 is artificially tempered to provide the maximum possible strength and hardness for our In-Ear Monitors.
True 3-Way Crossover
- By utilizing a true 3-way crossover, Symphonium Audio are able to tune each driver to the exact specifications they require, achieving the best possible sound
Hand Matched Components
- Using only the highest quality Panasonic and Vishay components, they are further hand-matched to attain better channel matching
Finest Details
- To squeeze out every bit of performance, Triton comes standard with Azla SednaEarfit Standard tips, for an uncompromised listening experience.
Specifications
| Title | Description |
| Driver Crossover | Custom Tuned True 3-Way Crossover with FLAT Technology |
| Frequency Response | 11Hz - 21kHz, ± 3 dB |
| Sensitivity | 107dB/Vrms @ 1 kHz |
| Impedance | 8.3 Ohms @ 1 kHz |
| Socket | Spring Loaded 0.78mm 2-Pin |
| Cable | 26 AWG Silver Plated OCC Copper |
| Cable Impedance |
0.20 Ohms (2.5mm) 0.25 Ohms (3.5mm) 0.28 Ohms (4.4mm) @ 1kHz |
| Warranty | Limited 1-Year Warranty |
