Sumiko
Sumiko Rainier MM Phono Cartridge - Clearance
Regular price $119
Sale price $119 Regular price $179.00
Save 34%
1 of 3
Sumiko
On saleClearance
Regular price $119
Save 34%
A refined and friendly introduction to the new Oyster line
Sumiko Rainier marks the beginning of the newest generation of Oyster moving magnet cartridges. Its resonance optimized housing was developed to improve clarity and expand the soundstage while keeping the gentle warmth that has defined the Oyster family for decades. The result is a cartridge that sounds full and easy to enjoy, with better imaging and a quieter backdrop than typical entry level options.
Rainier presents instruments and vocals with a natural sense of space, placing them confidently within the stage. The overall character is round and inviting, with smooth highs, well controlled mids and bass that carries impact without losing balance. It performs well across a wide range of systems and is a strong starting point for listeners building their first serious analog setup.
Part of the latest Oyster series
Rainier, Olympia and Moonstone were created to build upon the long established strengths of the Oyster line. Their redesign focuses on how resonance moves around the cartridge body and how to dissipate it before it affects the generator. This gives the new models an ease and transparency that enhances natural harmonics, adds realism to attack and decay and presents music against a quieter background that is usually associated with moving coil designs.
Flexible upgrade path
All styli for Rainier, Olympia and Moonstone fit the same cartridge body. This means you can start with Rainier and change to an Olympia or Moonstone stylus later for a clear performance upgrade without buying a new cartridge. It also makes it easy to keep a spare stylus on hand or maintain a secondary stylus for older or well loved records.
Hand crafted in Japan
Every Sumiko cartridge is hand assembled in Yokohama by trained technicians. Materials are selected through listening tests, each model is tuned until it meets its intended character and every unit is built with careful attention to detail. The result is a cartridge that performs reliably and brings a consistent musical signature to a wide range of tonearms.
Key features
  • Moving magnet design with 5.0 mV output
  • 0.3 x 0.7 mil elliptical stylus for smooth, controlled playback
  • Warm tonal balance with improved clarity and stage width
  • Quiet operation that outperforms typical entry level cartridges
  • Compatible with all standard 47 kohm MM phono stages
  • Interchangeable styli across Rainier, Olympia and Moonstone
  • Hand crafted in Yokohama, Japan
Specification Details
Cartridge Type Moving Magnet (MM)
Stylus 0.3 x 0.7 mil elliptical
Cantilever Aluminum pipe
Coils High purity copper
Output 5.0 mV
Internal Impedance 1,130 ohms
Load Impedance 47 kohms
Frequency Response 15 Hz to 25 kHz
Channel Separation 25 dB at 1 kHz
Channel Balance 1.5 dB at 1 kHz
Compliance 10 x 10-6 cm per dyn at 100 Hz
Capacitance 100 pF to 200 pF
Vertical Tracking Angle 25 degrees
Tracking Force Range 1.8 g to 2.2 g
Recommended Tracking Force 2.0 g
Cartridge Weight 6.5 g
Dimensions (W x H x D) 17.2 x 18.8 x 29 mm
Replacement Stylus RS Rainier, RS Olympia or RS Moonstone
What is in the box
  • Sumiko Rainier MM phono cartridge
  • Pre installed elliptical stylus
  • Mounting hardware
  • Documentation
