Sumiko
Sumiko Pearl Phono Cartridge - Clearance
A long loved classic in the Oyster line
The Sumiko Pearl sits at the top of the entry range in the classic Oyster Series and has been delighting listeners for decades. It is widely compatible with most tonearms and works with any standard moving magnet phono stage, making it an easy upgrade for vinyl enthusiasts who want better clarity, stronger imaging and a more engaging musical presentation without overspending.
Pearl keeps the smooth and friendly character of its sibling, the Black Pearl, but raises the level of refinement with a 0.3 x 0.7 mil elliptical stylus. This stylus retrieves more detail, improves stereo separation and brings greater sparkle to the upper frequencies. The result is an evenly balanced cartridge with open and inviting highs, confident mids and deep, well rounded bass.
A foundation of the classic Oyster line
The Oyster Series has been a trusted part of the analog world for more than forty years. Models in this line are known for honest reproduction, musical warmth and impressive value. Pearl carries that tradition forward with a sound that is smooth, dynamic and easy to enjoy for long listening sessions. It is a reliable choice for a wide range of turntables and continues to outperform expectations in its price range.
Hand crafted in Japan
Every Sumiko cartridge is assembled by hand in Yokohama by skilled craftsmen who evaluate materials by ear and tune each design until it reaches its intended character. The result is consistent performance, dependable build quality and a long tradition of cartridges that help vinyl systems reach their full potential.
Key features
- Moving magnet design with 4.0 mV output
- 0.3 x 0.7 mil elliptical stylus for improved detail and imaging
- Smooth, musical and evenly balanced tonal character
- Deep, well rounded bass and clear midrange
- Compatible with nearly all MM phono stages
- Hand crafted in Yokohama, Japan
| Specification | Details |
| Cartridge Type | Moving Magnet (MM) |
| Stylus | 0.3 x 0.7 mil elliptical |
| Cantilever | Aluminum pipe |
| Coils | High purity copper |
| Output | 4.0 mV at 1 kHz |
| Internal Impedance | 1,130 ohms |
| Load Impedance | 47 kohms |
| Frequency Response | 12 Hz to 30 kHz |
| Channel Separation | 30 dB at 1 kHz |
| Channel Balance | 0.5 dB at 1 kHz |
| Compliance | 12 x 10-6 cm per dyn at 100 Hz |
| Capacitance | 100 pF to 200 pF |
| Vertical Tracking Angle | 25 degrees |
| Tracking Force Range | 1.5 g to 2.0 g |
| Recommended Tracking Force | 2.0 g |
| Cartridge Weight | 6.0 g |
| Dimensions (W x H x D) | 11.6 x 20.26 x 27.24 mm |
| Replacement Stylus | RS Pearl |
What is in the box
- Sumiko Pearl MM phono cartridge
- Pre installed elliptical stylus
- Mounting hardware
- Documentation
Frequently Asked Questions
What turntables is the Pearl compatible with
Pearl works with most half inch mount tonearms and any standard 47 kohm MM phono stage. It is a straightforward fit for many modern and vintage turntables.
Is the stylus user replaceable
Yes. The RS Pearl stylus is the direct replacement and installs easily without tools.
How does Pearl compare to the Black Pearl
Pearl delivers more detail, stronger imaging and greater extension thanks to its elliptical stylus. It offers a balanced and more refined presentation compared to the Black Pearl.
Is Pearl suitable for older or well loved records
Yes. The elliptical stylus offers improved detail while still being forgiving enough for mixed condition collections.
What tracking force should I use
Pearl performs best at 2.0 grams of tracking force.
