Sumiko
Sumiko Olympia MM Phono Cartridge - Clearance
Regular price $129
Sale price $129 Regular price $219.00
Save 41%
1 of 3
Sumiko
On saleClearance
Regular price $129
Save 41%
Greater nuance, better speed and a more open stage
Sumiko Olympia sits above Rainier in the latest Oyster lineup and brings meaningful improvements in clarity, nuance and frequency extension. An upgraded cantilever assembly reduces moving mass, which helps the stylus trace grooves with more agility and precision. A small drop in output lowers the already quiet noise floor, improving stereo imaging and helping Olympia present music with a realism that stands out at this price.
The sound is more articulate and more open than Rainier, with better control through the midrange and smoother, more extended highs. It stays musical and forgiving but offers a noticeable increase in refinement for systems that can reveal the difference.
Part of the latest Oyster series
Rainier, Olympia and Moonstone are the newest additions to the Oyster line and were created to enhance the long standing character of these cartridges. Their housings are designed to disperse resonance before it reaches the generator, which lifts transparency and builds a quieter backdrop for vocals and instruments. The voicing stays natural and easy to enjoy, with a level of nuance and spatial clarity that is reminiscent of moving coil designs.
Flexible upgrade path
The Rainier, Olympia and Moonstone families share the same cartridge body, which allows all three styli to be used interchangeably. You can begin with Olympia and move up later by installing a Moonstone stylus or keep a Rainier stylus as a secondary option for worn or older records. This approach lowers long term cost and makes it easy to tailor your sound.
Hand crafted in Japan
Every Sumiko cartridge is assembled by hand in Yokohama by experienced builders. Materials are selected by ear, production is tuned through careful listening tests and each unit is built with an emphasis on precision and long term reliability. The result is a cartridge that brings consistent character and strong value to a wide variety of analog setups.
Key features
  • Moving magnet cartridge with 4.0 mV output
  • 0.3 x 0.7 mil elliptical stylus for improved detail and smooth extension
  • Lower moving mass for faster, more accurate groove tracing
  • Quieter background and improved imaging over Rainier
  • Compatible with any standard 47 kohm MM phono stage
  • Interchangeable styli across Rainier, Olympia and Moonstone
  • Hand crafted in Yokohama, Japan
Specification Details
Cartridge Type Moving Magnet (MM)
Stylus 0.3 x 0.7 mil elliptical
Cantilever Aluminum pipe
Coils High purity copper
Output 4.0 mV
Internal Impedance 1,130 ohms
Load Impedance 47 kohms
Frequency Response 12 Hz to 30 kHz
Channel Separation 30 dB at 1 kHz
Channel Balance 1.5 dB at 1 kHz
Compliance 12 x 10-6 cm per dyn at 100 Hz
Capacitance 100 pF to 200 pF
Vertical Tracking Angle 25 degrees
Tracking Force Range 1.8 g to 2.2 g
Recommended Tracking Force 2.0 g
Cartridge Weight 6.5 g
Dimensions (W x H x D) 17.2 x 18.8 x 29 mm
Replacement Stylus RS Rainier, RS Olympia or RS Moonstone
What is in the box
  • Sumiko Olympia MM phono cartridge
  • Pre installed elliptical stylus
  • Mounting hardware
  • Documentation
