Sony
Sony WHX-XB910N Wireless Headphones - Clearance
Regular price $79.99
Sale price $79.99 Regular price $248.00
Save 68%
1 of 8
Sony
On saleClearance
Save 68%
Sony WH-XB910N Wireless Noise Cancelling Headphones
Get closer to your music with the Sony WH-XB910N. Designed for listeners who want deep, punchy bass without sacrificing clarity, these wireless over-ear headphones combine EXTRA BASS tuning with advanced Dual Noise Canceling technology for an immersive everyday listening experience.
EXTRA BASS With Control
Sony’s EXTRA BASS technology enhances low-frequency response for powerful impact while preserving vocal clarity. A dedicated bass duct and improved air-tightness around the ear help deliver tight, controlled bass that adds energy without overwhelming the mix.
Advanced Noise Canceling
Dual Noise Canceling uses both feedforward and feedback microphones on each ear cup to reduce ambient noise more effectively. Whether commuting, traveling, or working, the WH-XB910N lets you focus on your music with fewer distractions.
Clear Calls and Smart Switching
Precise Voice Pickup technology uses dual microphones and advanced signal processing for clear voice calls. Multipoint Bluetooth connectivity allows you to connect to two devices at once and switch automatically when calls come in.
All-Day Battery Life
Enjoy up to 30 hours of playback with noise canceling enabled. When time is short, a 10 minute quick charge provides up to 4.5 hours of listening with a compatible charger.
Touch Controls and Smart Assistants
Touch controls let you adjust volume, change tracks, and manage calls with simple gestures. Place your hand over the ear cup to temporarily lower music volume and let ambient sound in. Built-in support for Google Assistant and Alexa adds hands-free convenience.
Product Highlights
  • EXTRA BASS tuning for deep, punchy low end
  • Dual Noise Canceling technology
  • Multipoint Bluetooth connection
  • Up to 30 hours of battery life
  • Quick charge support
  • Clear call quality with dual microphones
  • Touch panel controls
  • Google Assistant and Alexa compatible
Headphone Type Closed-back, dynamic
Wearing Style Over-ear, circumaural
Driver Size 25 mm dome type
Magnet Neodymium
Frequency Response 5 Hz to 40,000 Hz
Sensitivity 100 dB/mW powered, 95 dB/mW passive
Impedance 50 Ω powered, 18 Ω passive
Noise Control Active Noise Cancellation
Bluetooth Multipoint supported
Battery Life Up to 30 hours
Quick Charge 10 min for up to 4.5 hours
Cable Length 1.2 m detachable
Weight 1.7 lb
What’s In The Box
  • Sony WH-XB910N wireless headphones
  • Carrying case
  • Detachable audio cable
  • USB-C charging cable
FAQ
Does the WH-XB910N support wired listening?
Yes. The headphones include a detachable cable for wired listening when the battery is low or when wireless use is not permitted.
Can I connect the WH-XB910N to two devices at the same time?
Yes. Multipoint Bluetooth allows connection to two devices simultaneously and switches automatically for incoming calls.
Is noise canceling adjustable?
Yes. Noise canceling and ambient sound features can be adjusted through touch controls and compatible devices.
Is a carrying case included?
Yes. A protective carrying case is included for travel and storage.
