Sony
Sony INZONE H9 Wireless Noise-Canceling Gaming Headphones - Clearance
Immerse yourself in PC and PlayStation 5 gaming with the Sony INZONE H9 Wireless Noise-Canceling Gaming Headset. Designed for competitive and immersive play, the INZONE H9 combines low-latency wireless performance, active noise cancellation, and clear voice communication to keep you focused on every match.
Wireless Gaming Freedom
The INZONE H9 supports dual wireless connectivity via a low-latency 2.4 GHz USB transceiver and Bluetooth 5.0. This allows you to game wirelessly while simultaneously taking calls or chatting over Bluetooth, delivering true cable-free convenience.
Immersive Gaming Sound
Equipped with 40mm dynamic drivers tuned specifically for gaming, the H9 delivers clear positional audio that helps you detect footsteps, gunfire, and environmental cues with precision. Support for 360 Spatial Sound for Gaming on PC enhances directional awareness for competitive play.
Active Noise Cancellation and Ambient Sound
Sony integrates Dual Noise Sensor Technology, derived from its flagship noise-canceling headphones, to block out distractions during gameplay. When awareness is needed, Ambient Sound Mode lets outside sounds through instantly, allowing you to stay connected to your surroundings.
Clear Team Communication
The attached boom microphone delivers clear and intelligible voice chat. Flip the microphone upward to instantly mute, and manage volume, chat balance, and noise control directly from the earcup controls.
PlayStation 5 Optimized
Designed with PlayStation 5 in mind, the INZONE H9 supports Tempest 3D AudioTech for immersive spatial audio. On-screen notifications confirm headset settings, while dedicated controls make it easy to balance game and chat audio.
Long Battery Life with Quick Charge
Enjoy up to 32 hours of wireless gameplay on a full charge. A quick 10-minute charge provides up to one hour of use, and the headset supports play-while-charging via USB for extended sessions.
Key Features
- Dual wireless connectivity via 2.4 GHz and Bluetooth 5.0
- 40mm dynamic drivers optimized for gaming audio
- Active noise cancellation with Ambient Sound Mode
- 360 Spatial Sound for Gaming on PC
- Tempest 3D AudioTech support for PlayStation 5
- Flip-to-mute boom microphone
- Up to 32 hours of battery life
- Discord certified for voice communication
| Wearing Style | Over-ear, circumaural |
| Driver Size | 40 mm |
| Frequency Response | 5 Hz to 20 kHz |
| Active Noise Cancellation | Yes |
| Wireless Connectivity | 2.4 GHz USB, Bluetooth 5.0 |
| Bluetooth Codecs | AAC, SBC |
| Microphone | Bidirectional boom microphone |
| Battery Life | Up to 32 hours |
| Quick Charge | 10 minutes for up to 1 hour |
| Charging | USB-C |
| Weight | 330 g |
| Color | White |
| Platform Support | PlayStation 5, Windows PC |
What’s In The Box
- Sony INZONE H9 Wireless Noise-Canceling Gaming Headset
- USB wireless transceiver
- USB-A to USB-C charging cable
