Softears
Softears Volume S In-Ear Headphones
Wearing style
Driver type
Dynamic, Balanced Armature
Portability
The Softears Volume S is a next-generation in-ear monitor designed for audiophiles seeking premium sound quality, advanced tuning options, and exceptional craftsmanship. As the successor to the highly acclaimed Softears Volume, the VolumeS features significant upgrades in design, driver configuration, and tuning technology. With its innovative hybrid driver setup, dual tuning modes, and high-end components, the VolumeS is engineered to deliver a powerful and detailed audio performance that adapts to your preferences.
Innovative Dual-Tuning Modes for Custom Sound
The Softears VolumeS provides two distinct sound profiles, allowing you to tailor your listening experience to different genres. Using a Japanese Copal dual-mode switch, you can seamlessly switch between Classical and Pop tuning modes. The Pop mode offers a vibrant sound signature with enhanced resolution and detail, following the HRTF room acoustic system curve, making it ideal for modern pop music. The Classical mode, on the other hand, delivers a natural and immersive listening experience, perfect for instrumental and orchestral genres. This innovative design introduces the concept of Bus Impedance, ensuring a seamless and dynamic audio transformation between both modes.
Hybrid Driver Configuration for Exceptional Performance
The Volume S features a sophisticated hybrid driver setup, combining a 10mm silicone diaphragm active dynamic driver with a 6mm wool paper diaphragm passive dynamic driver. This unique combination enhances the bass response, delivering deep, rich, and textured low frequencies. Additionally, the VolumeS incorporates dual self-developed balanced armature drivers, combining ED and WBFK units for full-frequency performance. This advanced driver configuration ensures an immersive audio experience with outstanding clarity across the frequency spectrum.
Precision Acoustic Design for Superior Sound
Softears has meticulously engineered the VolumeS with a low-latency acoustic duct structure to maintain smooth and consistent phase coherence. The acoustic tubes are designed with minimal bending angles and the shortest possible length, ensuring accurate signal transmission and reducing distortion. This precision-crafted design enhances the overall sound quality, delivering a natural and detailed audio performance.
Flagship-Level RC Tuning Network for Pristine Audio
Borrowing technology from the flagship Softears RS10, the Volume S features a high-precision RC tuning network electronic crossover. This three-way crossover system uses eight finely tuned components to ensure even impedance distribution and ultra-low signal loss across the frequency range. The result is a cleaner sound with enhanced adaptability and minimal distortion, offering a fuller and more dynamic listening experience.
Elegant Design and Comfortable Fit
The Softears VolumeS combines cutting-edge technology with exquisite craftsmanship. Its ergonomic shells are crafted using advanced 3D printing technology and high-quality resin for a comfortable fit and enhanced acoustic performance. The artistic faceplates are constructed with aluminum alloy and feature an inlaid carbon fiber design, giving the VolumeS a modern, premium aesthetic. The included high-quality paracord cable, with interchangeable 3.5mm and 4.4mm plugs, ensures versatility and durability for a wide range of audio setups.
| Feature | Details |
| Driver Configuration | 1 Active DD + 1 Passive DD + 2 BA Drivers |
| Frequency Response Range | 8Hz ~ 40kHz |
| Effective Frequency Response | 20Hz ~ 20kHz |
| Impedance | 9.8Ω @ 1kHz (Low Impedance Mode), 31.2Ω @ 1kHz (High Impedance Mode) |
| Sensitivity | 124dB/Vrms (Low Impedance Mode), 114dB/Vrms (High Impedance Mode) |
| THD+N | <1% @ 1kHz |
| Tuning Modes | Classical (HiFi) Mode, Pop Mode |
| Acoustic Design | Low-latency acoustic duct structure with RC tuning network |
| Connector Type | 2-Pin 0.78mm |
| Cable | High-quality braided paracord cable with interchangeable plugs |
| Termination Plugs | 3.5mm Single-Ended, 4.4mm Balanced |
| Shell Material | High-quality resin inner cavity with aluminum alloy and carbon fiber faceplates |
What's In the Box
- Softears VolumeS In-Ear Headphones
- High-Quality Paracord Cable with Interchangeable Plugs
- 3.5mm Single-Ended Plug
- 4.4mm Balanced Plug
- Dual-Tuning Switch Tool
- Protective Carrying Case
- Ear Tip Set (Various Sizes)
- User Manual
- Warranty Card
The Softears VolumeS is an exceptional IEM that seamlessly blends innovative engineering, artistic design, and unparalleled sound performance. Whether you're an audiophile or a casual listener, the VolumeS offers an immersive and customizable listening experience, making it a perfect choice for discerning music lovers. Available now at Headphones.com.
