Sennheiser
Sennheiser IE 200 In-Ear Headphones
Regular price $159.95
Sale price $159.95 Regular price $159.95
1 of 4
Sennheiser
Pre-pay to reserve Pre-Orders for the IE 200 go live January 17th
Reference tuning for an entry-level price
Why not make balanced, high-fidelity sound available to everyone, no matter where they are? The IE 200 is Sennheiser’s answer. Whether you’re a lifelong audiophile — or you just want better sound on the road — these exceptionally neutral and precise earphones reveal an entire world of new detail.
Highlights
  • Diffuse-field equalization for amazingly balanced sound
  • Nearly zero total harmonic distortion
  • Compact dimensions to fit any ear, large or small
  • Adjustable ear hooks and choice of ear tip adapters
  • No peaks or troughs to cause masking
  • Frequency response: 6 Hz – 20,000 Hz
  • Braided cable with MMCX connectors and 3.5mm plug
The Big Reveal
Enjoy the music you love like never before with the smallest details unmasked
Maybe it’s three extra notes in a bass line you’d never noticed. Or that flute playing a quiet melody in the background. Every time you discover a new musical flourish in a favorite track, it’s like finding buried treasure.
The tonal balance of the IE 200 showers you with these gifts. Because our engineers spent considerable effort to eliminate the peaks and troughs that can otherwise swallow up or overshadow a particular note. It’s an upgrade for your entire music collection.
Pure Joy for Audiophiles, Too
This time, accessibility does not mean compromise
Die-hard audio fans have little patience for “bathtub” sound: that’s a profile that rises dramatically at the bass and treble ends (the frequency response curve looks like a bathtub!) You’ll find nothing of the sort with the exquisitely neutral IE 200.
In tuning these in-ears, our engineers pulled out all the stops to achieve a diffuse-field equalized response that comes exceptionally close to the ideal. It’s quite an achievement for in-ears. Now you can take real audiophile sound with you everywhere.
Wires Have Never Been This Sexy
For ultimate sound quality and dependability, nothing beats a cable
No matter how amazing your wireless earbuds are, you still have to charge them. With the IE 200, all you need to remember is to plug them in. Ahh, and when you do … you’ll be completely enveloped in a world of brilliantly balanced sound. Full of detail and presence like you’ve never experienced.
Graceful, all-black aesthetics perfectly reflect this devotion to fidelity. The highly adaptable chassis fits comfortably in any ear, from large to even very small — underscoring our clear intent to make audiophile sound accessible to anyone and everyone.
Built Around the True Response
At the heart of the IE 200 lies a mini-transducer so exceptional, it also drives our most renowned in-ears
The IE 200 takes advantage of some of the best in-ear technology we have to offer. The 7mm extra-wideband True Response transducer, for instance, exhibits virtually no harmonic distortion at all. That’s why you’ll also find it in our IE 300, IE 600 and IE 900.
This dynamic driver reproduces transients with great precision across the entire frequency range — so you can hear exactly what the sound engineer intended. The snare drum cuts through the mix like it’s supposed to; close your eyes, and lifelike sibilants make it feel like the vocalist is in the room, singing just for you.
Choose Your Own Bass
Dual-tunable ear tips let you pick the bass response you like best
When it comes to lower frequencies, some like it a little heavier. To truly appeal to everyone, the IE 200 gives you the option to tune your earphones to your taste. Simply mount the ear tips in one of two positions to determine how much low end reaches your ears.
It's just one more reason the IE 200 is destined to make music lovers happy the world over. For jazz, EDM, classical, or punk rock — now everyone can experience high-resolution, audiophile sound. And if you like, with a little extra punch down low.
Specifications
  • Ear coupling: Ear canal
  • Transducer principle: dynamic
  • Transducer size: 7mm
  • Acoustic principle: closed
  • Jack plug: 3.5 mm angled
  • Cable length: 1.2 m
  • Weight: 4 grams
  • Frequency response: 6 - 20,000Hz
  • Impedance: 18 Ω
  • Sound pressure level (SPL): 119dB (1kHz, 1Vrms)
  • Total harmonic distortion (THD): <0.08 %
  • Country of origin Designed in Germany, assembled in China
What's In The Box?
  • Sennheiser IE 200 In-Ear Headphones
  • Braided Cable with MMCX Connectors and 3.5mm Plug
  • Silicone and Memory Foam Sets (S, M, L)
  • Pouch
  • Safety guide
