Pro-Ject Audio Systems
Pro-Ject Pre Box RS2 Digital Preamp w/ DAC & Headphone Amp - Clearance
Regular price $1,799
Sale price $1,799 Regular price $2,999.00
Save 40%
1 of 2
On saleClearance
Save 40%
The Pro-Ject Pre Box RS2 Digital is a high end preamplifier, DAC, and headphone amplifier built for listeners who want a single compact hub for serious two channel and headphone systems. It combines dual mono ESS9038Q2M DAC chips, fully balanced analog topology, a selectable tube or solid state output stage, and extensive digital input support in one chassis. Use it as a DAC and preamp for your power amplifier and speakers, as a high performance headphone amp, or as the digital control center of a full RS2 stack.
Based on the core design of the award winning Pre Box S2 Digital, the RS2 version pushes resolution, flexibility, and build quality much further. It supports PCM up to 32 bit 768 kHz, DSD up to DSD512, and full hardware MQA unfolding. With both XLR and RCA outputs, plus a discrete DC coupled headphone stage, it is as comfortable feeding a reference power amp as it is driving demanding headphones.
Dual mono DAC and digital architecture
Pre Box RS2 Digital uses two ESS9038Q2M converters in a dual mono layout, with fully separate signal paths for left and right channels. The USB input is handled by a powerful multi core XMOS controller, while an Altera CPLD manages reclocking. Together they reduce jitter and provide a stable digital foundation for conventional PCM, DSD, and MQA playback.
Sample rates up to 32 bit 768 kHz and DSD512 are supported through USB. Eight digital filter options are available, including the proprietary optimal transients filter from the MQA team, so you can fine tune the presentation to taste. Hardware MQA unfolding works on all digital inputs, including I²S, coaxial, optical, AES EBU, and USB.
Tube or solid state output
One of the defining features of Pre Box RS2 Digital is its selectable output stage. At the press of a button you can choose a fully discrete solid state path or a 6922 based tube output. This lets you match the sound to your system and mood. The solid state stage offers ultra low distortion and maximum linearity, while the tube mode adds a slightly more relaxed and harmonically rich character.
Both stages sit behind a fully balanced analog signal path with separate XLR and RCA outputs. Use it as a fixed level DAC, a variable level preamp, or directly into a power amp or active speakers.
Headphone amplifier
The built in headphone amplifier is a discrete, no compromise design. It is DC coupled with a fast servo to remove any DC offset, and it avoids coupling capacitors in the signal path. With power output up to 245 mW into 33 ohms and 90 mW into 300 ohms, it can handle a wide range of headphones from efficient dynamics to more demanding planar designs.
System integration and RS2 ecosystem
Pre Box RS2 Digital is designed to integrate cleanly into both standalone and stack based systems. It offers nine digital inputs, including I²S over HDMI for direct connection to Pro Ject’s CD Box RS2 T transport. In this configuration the Pre Box RS2 Digital can provide the master clock at 16.9344 MHz for improved timing.
Paired with a Stream Box S2 Ultra, it becomes a Roon Ready, network enabled front end for Tidal, Qobuz, local libraries, and more, with full MQA decoding. Trigger in and trigger out jacks make it easy to power the system on and off in sync with other RS2 components.
Build, interface, and control
The Pre Box RS2 Digital is housed in a solid aluminum enclosure and is available in black or silver. The front panel features a large 3.5 inch TFT display that clearly shows sample rate, input, filter, and status information. The interface is fast and direct, and a full aluminum remote control is included for easy operation from the listening position.
Product Type High end DAC, preamplifier, headphone amplifier
Digital to Analog Converters 2 x ESS9038Q2M 32 bit (dual mono)
Frequency Response 20 Hz to 20 kHz (-0.3 dB, -2.5 dB)
Output Voltage (RCA) 2.0 V RMS at 0 dBFS (digital inputs)
Output Voltage (XLR) 4.0 V RMS at 0 dBFS (digital inputs)
Sampling Rates (PCM) 32, 44.1, 48, 88.2, 96, 176.4, 192, 352.8, 384, 705.6, 768 kHz
DSD Support DSD64, DSD128, DSD256, DSD512 (DoP, DSD512 native)
MQA Support Full hardware unfolding for all digital inputs
Dynamic Range 124 dBA
Channel Separation Greater than -117 dB at 10 kHz, 0 dB
Signal to Noise Ratio Greater than 113 dB (20 Hz to 20 kHz, 0 dB)
THD (solid state) 0.005 percent
THD (tube output) 0.25 percent
THD (20 Hz to 20 kHz) Less than 0.0003 percent at 0 dB, 2 V RMS, 1 kHz
THD+N (20 Hz to 20 kHz) Less than 0.0009 percent
Analog Input Sensitivity 350 mV
Line Input Impedance 50 k ohms
USB Data Transfer Asynchronous, DSD DoP up to DSD512, PCM up to 32 bit 768 kHz
Optical Inputs 2 x S/PDIF Toslink (24 bit, 192 kHz)
Coaxial Input 1 x S/PDIF coax (24 bit, 192 kHz)
AES/EBU Input 1 x balanced (24 bit, 192 kHz)
I²S Input For CD Box RS2 T via HDMI (Pro Ject RS2 only)
Master Clock Output 16.9344 MHz for CD Box RS2 T
Filter Settings 8 digital filters including MQA optimal transients
Bluetooth Version Bluetooth v4.0
Bluetooth Codecs SBC, AAC, aptX
Output Buffer Discrete and balanced, tube and solid state selectable
Tubes 4 x 6922EH
Headphone Amplifier Discrete design
Minimum Headphone Impedance 8 ohms (recommended minimum)
Headphone Power Output 90 mW at 300 ohms, 245 mW at 33 ohms, 150 mW at 8 ohms
Display 3.5 inch TFT, 480 x 320, 360 cd/m², MVA
Balanced Analog Input 1 x XLR
Unbalanced Analog Input 1 x RCA
Balanced Analog Output 1 x XLR (variable)
Unbalanced Analog Output 1 x RCA (variable)
Headphone Output 1 x 6.3 mm stereo jack
Trigger Sockets 2 x 2.5 mm (1 in, 1 out)
Power Supply 20 V 3 A DC outboard supply
Power Consumption Max 1 A DC, less than 0.5 W in standby
Dimensions (W x D x H) 22.2 x 20.6 x 7.2 cm
Weight 1.17 kg
Finish Black or silver aluminum
What is in the Box
  • Pro-Ject Pre Box RS2 Digital
  • 20 V 3 A DC power supply
  • Aluminum remote control
  • Owner’s manual
FAQ
Can I use Pre Box RS2 Digital as a preamp into a power amplifier
Yes. The unit has variable level XLR and RCA outputs and is designed to act as a line preamp and DAC feeding a separate power amplifier or active loudspeakers.
What is the benefit of the tube output stage
The tube stage uses 6922EH tubes in a discrete balanced topology and offers a slightly warmer, more relaxed presentation. The solid state stage remains the best choice when you want the lowest distortion and the most neutral playback. You can switch between them from the front panel or remote.
Do I need a separate headphone amplifier
For most headphones the built in discrete headphone stage provides ample power and control. Very insensitive planars may still benefit from a dedicated high power headphone amplifier, but for many users the RS2 Digital will be more than enough.
How do I get the most out of MQA
Connect a Pro Ject Stream Box S2 Ultra or other MQA capable source via USB, coaxial, optical, AES EBU, or I²S. The RS2 Digital performs full hardware unfolding and rendering on all digital inputs, so you get the maximum MQA benefit with compatible content.
Is the I²S input compatible with other brands
No. The I²S over HDMI implementation in the RS2 series is proprietary to Pro Ject. It is designed specifically to work with the CD Box RS2 T and other RS2 components and will not follow external brands’ I²S pinouts.
Can I bypass the tube stage completely
Yes. When you select solid state mode the signal path uses the discrete solid state output stage and the tubes are not in the audio path.
Does Bluetooth support high quality codecs
The Pre Box RS2 Digital supports SBC, AAC, and aptX over Bluetooth v4.0. For the highest quality playback, USB, AES, coaxial, or I²S connections are recommended.
