1 of 5
Pro-Ject Audio Systems
Pro-Ject Audio Systems Debut PRO
Regular price $999
Sale price $999 Regular price
365-day returns
Sonic Club members get faster free shipping and earn 999 points on this purchase. Learn more
Regular price $999
Debut PRO Three-Speed Turntable
Pro-Ject Audio Systems Debut PRO three-speed turntable
Play your favorite 33 1/3, 45, and 78 rpm records through your stereo system with the satin black Pro-Ject Audio Systems Debut PRO Three-Speed Turntable. Design features such as CNC-milled aluminum parts and the unique deep-dish platter help prevent unwanted resonances from colouring your audio signal.
A MILESTONE FOR THE NEXT DECADES
The Debut PRO brings an absolutely new design to Pro-Ject turntables. The audiophile turntable is convincing in all respects – not only visually, but more importantly also in terms of sound.
The precision CNC milled parts are optically perfectly coordinated and lead the Debut PRO to its modern simple, elegant and unprecedented design. The nickel finish of all these aluminium components result in a hard, resistant surface. This process enables us to produce very high-quality and sustainable components and avoid plastics and similar materials that continue to age over time and would more importantly also degrade sound quality.
The tonearm bearing is a completely new design. Precision CNC'd out of a single block of aluminium, you can see all the production stages above. The last step is putting a nickel finish on it. This will increase the rigidity of the bearing, ensuring free and fluid movement of the tonearm and precise tracking without material degration in looks or function.
Deeply driven
The electronically regulated synchronous motor drives the platter and guarantees the most accurate and stable speeds. Change between them easily with the toggle switch. With the supplied round belt for 78 rpm you can also listen to your shellac records.
A new platter – a deeper dish
The new Debut PRO platter is a first on any Pro-Ject turntable. It features a notch for the record label and together with our Record Puck PRO (available separately) the puck's weight will press your record tightly against the platter. The die-cast aluminium platter is reworked and precision balanced in an extra step to obtain an evenly spinning platter. It is anti-magnetic, allowing MC cartridges to work properly. Delve deep into the vast upgrade path the Debut PRO has to offer!
The anti-magnetic heavy aluminium platter has a ring made of TPE (thermoplastic elastomer) on the inside that helps to dampen all resonances and minimizes wow and flutter. Our seperately available Record Puck PRO provides an extra level of damping and stability, so it is the perfect add-on for the Debut PRO.
HYBRID TONEARM
The new Debut PRO features a one-piece carbon-aluminium sandwich tonearm. The carbon layer gives the tonearm a high degree of rigidity, while the inner aluminium tube takes over the damping of the tonearm. This makes the tonearm perfect to be upgraded with higher-end MC cartridges!
AZIMUTH & VTA ADJUSTMENT
The newly designed tonearm base allows you to adjust both the azimuth and the vertical tracking angle (VTA). The tonearm height can be continuously adjusted by loosening the two grub screws. These settings give you the option of adapting the tonearm to height changes allowing the use of different turntable mats or other cartridges to always achieve the best sound quality. Setting and experimenting with the VTA & Azimuth is crucial in extracting every last bit of performance out of your cartridges.
Specifications
Download Specification Sheet
Download User Manual
Title Description
Speed 33, 45/(78) (electronic speed change)
Drive principle belt drive with electronic speed control
Platter 300mm, die cast aluminium platter with TPE damping and felt mat
Platter bearing high precision stainless steel axle in bronze bushing
Wow & flutter 33: +/-0,16%; 45: +/-0,14%
Speed drift 33: +/-0,40%; 45: +/-0,50%
Signal to noise 68dB
Tonearm 8,6” one-piece carbon-aluminium tonearm
Effective arm length/mass 218,5 mm / 10,0 g
Overhang 18,5mm
