Pro-Ject Audio Systems
Pro-Ject Connect it Phono DS 5P to XLR - Clearance
Regular price $99
Sale price $99 Regular price $199.00
1 of 1
Clearance
Regular price $99
The Pro-Ject Connect it Phono DS 5P to XLR cable is built for vinyl listeners who want a clean, low noise, balanced signal path from turntable to phono stage. With high purity OFC conductors, low capacitance, and strong shielding, it protects the delicate phono signal and preserves detail and clarity. This version provides a 5 pin DIN to dual XLR connection for turntables and preamps that support balanced operation.
DS Series Construction
The Connect it DS cable uses high purity OFC conductors and a low capacitance design that is ideal for phono signals. A helical OFC shield and conductive TPE sub jacket protect the signal from interference while keeping the cable flexible. Silver plated signal pins are used on every connector for higher conductivity and lower resistance.
Termination is 5 pin DIN to dual standard XLR connectors. This makes the cable a strong option for balanced phono setups that use turntables with DIN tonearm outputs.
Pro-Ject Cable Line Overview
Pro-Ject organizes its cables into four series. E, S, DS, and RS. Each series steps up in conductor quality, shielding, and connector design. The DS line sits above the E and S series, offering stronger shielding, improved materials, and additional balanced termination options including XLR and 5 pin DIN.
Series DS
Length 1.23 m
Conductor Material High purity OFC
Shielding Helical OFC with conductive TPE sub jacket
Connector Type 5 pin DIN to dual XLR
Signal Pins Silver plated
Use Case Balanced phono connection
What is in the Box
  • Pro-Ject Connect it Phono DS 5P to XLR Cable 1.23 m
