Noble Audio
Noble Audio Osprey Wireless In-Ear Headphones
Regular price $199
Sale price $199 Regular price $199.00
1 of 16
Noble Audio
Regular price $199
Dynamic, Balanced Armature
Wireless
The Noble Audio Osprey brings the character of Noble’s in-ear monitors into a true wireless headphone built for daily use. It is the most accessible model in Noble’s wireless lineup, but it still carries the things people come to Noble for: a more considered tuning, a hybrid driver design, and a visual identity that feels crafted rather than mass-produced.
At $199, Osprey is not trying to be another disposable pair of wireless earbuds. It is an entry point into the Noble ecosystem, made for listeners who want something easy to use every day without giving up on sound, comfort, or design. You get active noise cancellation, Transparency Mode, LDAC support, Bluetooth 5.4, app-based EQ, and a compact charging case, all wrapped around a dual-driver acoustic design that gives Osprey more depth and refinement than a typical single-driver true wireless earbud.
Noble Sound, Made for Everyday Listening
Osprey uses a hybrid driver system with a 10mm dynamic driver and a custom balanced armature in each earpiece. The dynamic driver gives the sound its weight, warmth, and low-end control. The balanced armature adds clarity and separation through the mids and treble, helping vocals, instruments, and small details come through with better focus.
The tuning is clean, balanced, and easy to enjoy. Bass has enough presence to keep music engaging, but it does not overwhelm the midrange. Vocals sound natural and clear. Treble has enough extension to bring out detail without turning sharp or fatiguing. It is the kind of sound that works across a full day of listening, whether you are playing music, watching video, taking calls, or using Osprey on the move.
A True Wireless Earbud That Still Looks Like a Noble
One of the easiest ways to spot a Noble product is the faceplate, and Osprey keeps that tradition alive. Each earpiece features a distinctive acrylic faceplate with layered, fluid patterns that give the design depth and individuality. It looks more like a small universal IEM than a generic wireless earbud, which is exactly what makes it feel different.
The shell is lightweight and ergonomic, with a fit designed for comfort, stability, and consistent passive isolation. Osprey is built to be worn every day, but it still has the premium feel and visual personality that Noble fans expect.
Wireless Features That Fit Real Life
Osprey is built around Bluetooth 5.4 and the Airoha 1571 chipset for stable modern wireless performance. Codec support includes SBC, AAC, and LDAC, giving compatible Android devices access to higher-quality wireless playback while keeping broad compatibility with phones, tablets, laptops, and everyday sources.
Active Noise Cancellation helps reduce outside noise when you want to focus, while Transparency Mode lets the world back in when you need awareness. Multipoint connectivity makes it easier to move between devices, and TrueWireless Mirroring helps keep the experience smooth whether you are listening to music, taking a call, or switching from your laptop to your phone.
Designed to Stay in Rotation
Battery life is rated for up to 7 hours with ANC off and up to 5 hours with ANC on. The 500mAh charging case extends your listening time, and a 10-minute quick charge gives you roughly 2 hours of playback when you need a quick top-up.
The Noble Audio app adds EQ control and over-the-air updates, giving you more room to shape the sound and keep the earbuds current over time. Osprey keeps the experience simple, but not stripped down. It gives you the wireless features you actually use, the design language Noble is known for, and a sound that feels more polished than the price suggests.
Key Features
  • Most accessible true wireless model in Noble Audio’s lineup
  • Hybrid dual-driver design with 10mm dynamic driver and custom balanced armature
  • Clean, balanced tuning with controlled bass, natural mids, and clear treble
  • Bluetooth 6.0 with Airoha 1571 chipset
  • SBC, AAC, and LDAC codec support
  • Active Noise Cancellation for reducing outside noise
  • Transparency Mode / Hearing Through for environmental awareness
  • Multipoint connectivity for switching between devices
  • TrueWireless Mirroring for seamless wireless operation
  • Dual microphones with cVc noise reduction for clearer calls
  • Up to 7 hours playback with ANC off
  • Up to 5 hours playback with ANC on
  • 10-minute quick charge provides approximately 2 hours of playback
  • USB-C charging
  • Noble Audio app support with EQ and OTA updates
  • Distinctive acrylic faceplates with layered, fluid patterns
  • Compact aluminum charging case
Technical Specs
Product Type True wireless in-ear headphones
Driver Configuration Hybrid dual-driver system
Drivers 10mm dynamic driver + custom balanced armature
Chipset Airoha 1571
Bluetooth Bluetooth 6.0
Supported Codecs SBC, AAC, LDAC
Frequency Response 20Hz to 40kHz
Sensitivity 104 +/- 3dB at 1kHz
Impedance 32Ω
Noise Control Active Noise Cancellation and Transparency Mode / Hearing Through
Connectivity Multipoint connectivity, TrueWireless Mirroring
Microphones Dual microphones with cVc noise reduction
Battery Life Up to 7 hours with ANC off, up to 5 hours with ANC on
Quick Charge 10 minutes for approximately 2 hours of playback
Charging Case Battery 500mAh
Charging USB-C
App Support Noble Audio app with EQ and OTA updates
Customer Reviews
Overall rating: 3.8 / 5 from 4 reviews.
Having returned from a cross country flight, I confirm an excellent amount of noise cancellation/isolation. This might feature more prominently in the review of this product, and it rates among the best I have experienced (I am not one to wish for a sensory isolation chamber, and you could hear-- faintly-- the airport and airplane announcements). This receives Four Stars because, while good, the sound quality is not a huge step up from AirPods I have experienced in the $100-160 range when listening critically in a quiet space. The soundstage is adequate, and the listening spectrum leans towards the mid. I am not a bass fiend but found myself wanting a bit more power-- even if the imaging was good (say for example Charlie Hayden/Jim Hall). They are better with female voices (Desandre, Lezhneva, Upshaw), but still good overall. Recommended, though I might be tempted to try around this price point, including wired IEMs, which I also shopped at the time. Decent charge time, and-- importantly in my experience-- not finicky about making the charge connection in the storage box. Materials are of good, though not necessarily premium, quality. I did not exhaust them from going through security, a four hour flight, waiting at the carousel, and on the shuttle back to my vehicle at moderate to high volume). Also among the easiest to pair Bluetooth-- no drama). For a near audiophile experience which bypasses the separate amplifier/iPhone/iPad approach, these are a solid choice. Recommended by a helpful chat participant.
Has a great sound for the price. I am very happy with them. I got them for the great sound and price, and I don't care about the other features so this is biased on sound quality only. Now I do have some ear buds that sound some better, but they cost at least twice as much. I will be listing to these quite a bit. I do recommend them. You will need to use the custom EQ to get the sound you prefer
