Moondrop
Moondrop S8 In-Ear Headphones - Open Box
Regular price $599
Sale price $599 Regular price $699.99
Save 14%
1 of 3
Moondrop
Regular price $599
Save 14%
Balanced Armature
Moondrop S8 Review - Kilobuck Solution - Written Review by Precogvision
Exquisite Craftsmanship:-
Though Moondrop is already very famous for their exquisite craftsmanship, they out did themselves here with the Moondrop S8.
The Moondrop S8 is a completely handmade set of IEM, everything from housing, soldering PCB's, wirings, assembling, and more are done by trained
craftsman's with utmost perfection and precision.
Moondrop has ensured at every step that every set of Moondrop S8 is built with the best of the materials and perfection which is even reflected through the transparent shells.
Every unit of Moondrop S8 has passed four acoustic sound tests to ensure sound consistency, which again reflects the brilliant craftsmanship of our staff.
Eight Drivers For That Sound Perfection:-
Moondrop has perfectly tuned and did a crossover of eight balanced armature drivers each side, which provide life-like sound quality with crisp details and quick sound response.
They have chosen a two balanced armatures for the lower end offering quick and thumpy bass response, four balanced armatures for natural and lifelike mids rich with details and two balanced armatures for detailed treble response.
All the drivers are arranged in a zero phase distortion crossover to provide rich sound quality with zero distortions.
They have selected sonion 37 series double bass driver for lower end and a knowles balanced armature driver unit for the treble part.
OCC Internal Wiring:-
The exquisite craftsmanship of Moondrop is not only on the outer side, we have used original copper cable wires for internal wiring, which ensures there is no detail loss and sound is reproduced as it is recorded.
Sound Quality To Touch Your Soul:-
With the help of professional tuning and craftsmanship, the Moondrop S8 provides beautiful and lovely sound reproduction, whether you are a bass head or a neutral loving person, the Moondrop S8 offers great details and sound.
Different Balanced armature units connected together to create brilliant rich details in your music with wide and detailed soundstage.
The Moondrop S8 provides one with a brilliant sound signature with a smooth U shaped sound which is very rich in details.
Zero Phase Inconsistency:-
Usually Multi driver IEM's have an issue of phase inconsistency which results in narrower soundstage but, we at Moondrop have ensured that each and every set of S8 has zero phase inconsistency and provides you with wider soundstage full of details.
Technical Specifications:-
  • Eight Balanced Armature Driver Units each side
  • Impedance:- 16ohms @ 1kHz
  • Frequency Response:- 20Hz-40kHz
  • Effective Frequency Response:-20Hz-20kHz
  • Sensitivity:- 122dB
  • 2-Pin 0.78mm Connector Cable
  • Medical UV acrylic housing shells
  • 6N OFC 3.5mm cable
