Moondrop
Moondrop LAN In-Ear Headphones - Clearance
Regular price $25
Sale price $25 Regular price $45.00
Save 44%
1 of 4
Moondrop
On saleClearance
Regular price $25
Save 44%
The MOONDROP LAN is a high-performance entry-level in-ear headphone designed to deliver low distortion, wide bandwidth, and neutral tuning at an accessible price point. Drawing from hardware and acoustic technologies previously reserved for high-end dynamic driver earphones, LAN sets a new benchmark for budget-focused HiFi IEMs.
A newly developed large-size beryllium-plated dome composite diaphragm, high-efficiency internal magnetic structure, and a stainless steel shell manufactured via MIM powder metallurgy work together to provide refined sound quality, durability, and a premium tactile feel. Compact and lightweight, LAN is engineered for long-term comfort without sacrificing acoustic performance.
Key features
  • Large-size beryllium-plated dome composite diaphragm for low distortion and extended frequency response
  • 10mm dual-cavity dynamic driver with high-efficiency internal magnetic structure
  • MIM powder metallurgy stainless steel shell for durability and precise acoustic consistency
  • Scientifically tuned by MOONDROP’s acoustic R&D team for neutral and transparent sound
  • Interchangeable 0.78mm 2-pin cable design for flexible use cases
Sound and use case
LAN is tuned to closely follow MOONDROP’s VDSF Target Response, delivering a balanced and natural frequency response with ultra-low nonlinear distortion. The beryllium-plated dome minimizes split vibration in higher frequencies, while the flexible suspension enables controlled long-stroke movement for clean bass and smooth mids.
The result is a neutral timbre, open presentation, and clear soundstage that suits critical music listening, gaming, and professional monitoring. LAN offers accurate imaging and transparency that exceed typical expectations in its price class.
Technical specifications
Model LAN IEM with replaceable cable
Shell MIM stainless steel
Driver 10mm dual-cavity high-performance dynamic driver
Voice coil 0.03mm ultra-thin CCAW
Diaphragm Beryllium-plated dome composite diaphragm
Magnetic circuit N52 high-performance internal magnetic circuit
Acoustic filter Patented anti-blocking filter
Cable connector 0.78mm 2-pin
Plug 3.5mm single-ended
Frequency response 15Hz to 37kHz
Effective frequency response 20Hz to 20kHz (IEC60318-4, ±3dB)
Impedance 32Ω ±15% at 1kHz
Sensitivity 120dB/Vrms at 1kHz
Total harmonic distortion ≤0.5% at 1kHz, 94dB
What’s in the box
  • MOONDROP LAN in-ear headphones
  • Detachable 0.78mm 2-pin cable with 3.5mm plug
  • Ear tips
  • Documentation
