Moondrop
Moondrop Edge Wireless ANC Headphones
Regular price $59.99
Sale price $59.99 Regular price $89.99
Save 33%
1 of 8
Moondrop
Save 33%
Wireless
Moondrop Edge: High-Fidelity Portable Wireless ANC Headphones for Everyday Listening
The Moondrop Edge High-Fidelity Portable Wireless ANC Headphones are designed to elevate your daily listening experience. Whether commuting, working from home, or enjoying music on a leisurely evening, the Edge provides a seamless blend of comfort, portability, and exceptional sound quality. With advanced features like hybrid active noise cancellation, a 40mm beryllium-plated dynamic driver, and customizable tuning options, these headphones deliver an immersive audio experience in a lightweight, foldable design.
High-Performance 40mm Dynamic Drivers
The Edge is equipped with a 40mm dynamic driver featuring a beryllium-plated dome and a flexible composite diaphragm surround. This advanced driver design minimizes distortion and delivers an extended dynamic range. The result is a balanced tonal response, where clear vocals, intricate string sections, and deep bass lines come through with remarkable clarity. Whether you’re listening to classical compositions or bass-heavy tracks, the Edge ensures a premium audio experience.
VDSF Tuning for Natural Timbre and Detail
Using advanced acoustic measurement tools like the B&K 5128, the Moondrop Edge is calibrated with a VDSF-based frequency response. This tuning replicates how sound interacts with the human ear, offering a realistic and coherent soundstage. Busy mixes retain clarity, and quiet passages feel natural and immersive. Whether you're diving into intricate recordings or enjoying live performances, the Edge preserves the subtle nuances of every track.
Long-Range Connectivity with Bluetooth 5.4
Stay connected without interruptions thanks to Bluetooth 5.4 and support for LDAC codec. The Edge delivers high-resolution audio wirelessly, maintaining the detail and depth of your favorite tracks. With an extended range of over 164 ft (50 m) in open environments, you can move freely while enjoying stable and reliable connectivity. Perfect for large spaces, the Edge ensures you remain tether-free and uninterrupted during your listening sessions.
Hybrid ANC and Pass-Through Mode
Experience the power of hybrid active noise cancellation with four built-in microphones (two per side). The system dynamically monitors and reduces background noise, tackling everything from office chatter to the hum of an airplane engine. For times when you need to tune back into your surroundings, simply press the ANC button to activate the pass-through mode and join conversations without removing the headphones.
Extended Battery Life and Quick Recharge
The Moondrop Edge is equipped with a long-lasting battery that supports up to 48 hours of continuous playback. This means you can enjoy your favorite playlists, podcasts, and movies all day without needing to recharge. For those moments when you’re short on time, a quick 5-minute charge provides approximately 4 hours of listening, ensuring you're always ready to go.
Ergonomic Design for Comfort and Portability
Designed for extended wear, the Edge features oblique contoured ear pads filled with inert memory foam. These pads create a comfortable and stable acoustic seal, making them ideal for long conference calls or binge-listening sessions. The aluminum alloy hinge allows the headphones to fold compactly, ensuring easy storage in the included travel bag. Lightweight and durable, the Edge is built to accompany you on all your adventures.
Feature Details
Bluetooth Version 5.4
Supported Profiles A2DP / AVRCP / HFP / HSP
Audio Codecs SBC / AAC / LDAC
Transmission Range Over 164 ft (50 m) in open environments
Driver 40mm Dynamic Driver (Beryllium-Plated Dome + Composite Diaphragm Surround)
Hybrid ANC Four Microphones (Two per Side)
Battery Life Up to 48 Hours
Quick Charge 5 Minutes = ~4 Hours Playback
Full Charge Time ~1.5 Hours
Charging Port USB-C
THD+N Low-Distortion Design
Signal-to-Noise Ratio High SNR
Tuning Options Five Profiles via Moondrop App
Passive Listening Yes
Dual Device Connection Supported
Ear Pads Oblique Contoured with Inert Memory Foam
Foldable Design Yes (Aluminum Alloy Hinge)
Frequency Response Range 8Hz ~ 40kHz
Effective Frequency Response 20Hz ~ 20kHz
What’s In the Box
  • Moondrop Edge Wireless ANC Headphones
  • Storage Bag
  • USB-C Charging Cable
  • User Manual
  • Certificate
  • After-Sales Card
  • App QR Code Card
The Moondrop Edge is a perfect blend of innovative technology, premium sound quality, and ergonomic design. Whether you’re commuting, relaxing, or working, these headphones adapt effortlessly to your needs, delivering high-resolution audio and exceptional comfort. Available now at Headphones.com.
